Super 7 Mods
Super 7 Mods
Home › Forums › General Questions › Super 7 Mods
  • #24930
    Piero Franchi
      @pierofranchi37209
      #271108
      Piero Franchi
        @pierofranchi37209
        Hi guys
        I got quite a shock when I looked at phone photos of when I first bought my super 7, I checked out the date!!!! April 2015!!!!!!!!!
        o well, cant be to hard on my self for taking this long to do the re build on my super 7
        I have not done a paint job, its a full strip, clean paint rebuld etc.
        but in my defence, I have restored the bodywork of a VW beetle, and a MG maggnette, pluss held a job, etc etc
        O and bought two Tom Senior mills, one needing a strip down clean and build (no painting)
        Ok back to the long over due Super 7,
        Its not far from compleation, and I am starting to look at the effecs of possible upgrades.
        Are there any must do mods that I will kick my self for not doing now,???
        I would rather do any up grades at this stage rather than latter once its up and running
        #271109
        Hopper
          @hopper
          I think the last couple issues of MEW had some Myford mods in there that could be worth a look. But most stuff, say for instance GH Thomas re-settable dials for cross slide, top slide and leadscrew handwheel can be done at any time.
          #271112
          JA
            @ja
            I think, from experience, that cross slide and top slide locks are a must. I have used G H Thomas's top slide lock on two lathes. My present Myford lathe had a cross slide lock in the form of a grub screw which I have change to a G H Thomas type lock.
            Most of G H Thomas's items are nice to have but not necessities.
            JA
            #271116
            John Haine
              @johnhaine32865
              I've never needed either a crosslide or topsldie lock. The carriage lock on the other hand is very useful, worth fitting a lever to operate it. As it's a S7 I assume that it already has resettable dials? If not they are a must for manual machining (or add DROs).
              You could fit Dyson vac tubes over the leadscrew to keep the swarf off – see another thread here.
              Fit link belts instead of V belts for smoother drive. Replace single phase with 3-phase motor + VFD.
              Fit roller thrust bearings on crosslide and leadscrew.
              You could always go the whole hog and convert to CNC!
              Fit a detent to engage the bull wheel for headstock dividing.
              #271278
              Robbo
                @robbo
                If you have not had a bed and saddle regrind on your early lathe, you may like to consider J A Radford's modifications to the saddle which were in ME no 3418, 4 Jun 1971.
                This mod moves the pressure on the saddle guides from the inside of the front shear to the outside of the rear shear giving a much bigger surface area.
                Other things, such as a dowel in the topslide gib strip, locks for the saddle and cross-slide, can be done at any time with little disturbance to the set up.
