Andrew Moyes wrote:
I have just brought into use a new Super 7 Plus bought in the Myford closing down sale. Actually, it was made in 2001 and run as a demo machine at exhibitions but appears never to have cut metal
Mine was very similar provenance – I bought the long bed Connoisseur that was displayed at shows. And a total dog of a machine it turned out to be! It had never been run, which was just as well, since it vibrated so badly that no-one who heard it run would ever have dared buy a Connoisseur! So it wasn't just the 'siezing' problem that I've had to deal with, to that we can add:
Rattling, eccentric and wobbling countershaft pulley, motor out of alignment, wobbling motor pulley, motor clamping arrangements rattling, main spindle pulley wobbling and rattling, leadscrew bent, tailstock out of alignment in two planes, various grub screws loose – to mention just some of them. Net result – the machine was unusable as bought. Overall, I've formed the conclusion that the demo machines were thrown together, never test run, and perhaps even never intended for sale. At least, not before they'd been back into works for sorting out.
I've stripped it so many times that I can now take apart the spindle, countershaft, clutch and motor assemblies in less than 15 minutes! At least that's made me very familiar with the components of a big bore spindle assembly.
The spindle cannot be displaced left relative to the headstock casting itself by more than a midges nudger, otherwise the spindle would lock tight in the front bearing bush.
Changing the distance sleeve won't make any difference to where the spindle sits, the only effect of making/installing a longer one would be to shift the angular contact bearings leftwards to achieve the correct spindle/bush clearance for the front bearing, and push the gear sleeve left as well, thereby affecting the mating of the gear sleeve with the tumbler gears.
The spindle pulley then sits and runs against the right hand edge of the distance sleeve – since this abuts and is clamped against a step on the spindle, the pulley will sit in exactly the same position, once the front bearing clearance has been adjusted.
You say: The bronze gear on the end of the pulley does not fully engage the larger of the two gear on the backgear cluster by about 1/8", by which I take it that you mean that the large cluster gear sits to the right of the pulley gear, and overhangs it by 1/8", running into the groove between the end of the gear teeth and the bull wheel drive collar.
So, since the pulley is more or less correctly located (it must be, unless there's something else drastically wrong, and I can't think what that might be), your problem must be that it's the backgear cluster that's displaced to the right. Since the cluster gear position on the eccentric shaft is fixed, the eccentric shaft must be displaced to the right.
Have a look at the backgear operating lever – it should sit close to the front of the headstock casting, and, of course, the detent should engage with the holes in the casting. Since anything wrong there would be immediately obvious, I guess it's ok, so look at the protrusion of the eccentric shaft from the operating lever – there shouldn't be any, it should be flush.
If it does protrude, that will be the problem, fortunately it's easy to fix. There are two grub screws securing the lever to the shaft, undo them – they're bloody awkward to get at! Then insert a flat bladed screwdriver into the top detent hole and twiddle it round – there should be a slotted head grubscrew down there, that fixes the longitudinal position of the eccentric shaft by engaging in a groove in the shaft. Loosen the screw, so that the shaft can move, but keep a little turning pressure on the grubscrew. Push the shaft to the left whilst gently turning the grubscrew against the shaft and you should feel when the groove gets to the screw as it will suddenly turn and enter the groove. Keep turning the grubscrew to fully engage it, but don't tighten it onto the shaft or it will prevent it from rotating. Then engage the gears with the spindle, as per the instructions in the manual, re-fit the handle and tighten the grub screws.
Now, if my analysis of the problem is correct (here's hoping!), the cluster gears should align correctly and you can re-adjust the position of the bull wheel on the spindle. There should be a little clearance to the pulley, the book says 0.005", but I've not found this to be critical.
But if it's not fixed, there's one other possibility that I'm aware of, but this has to be very unlikely – assuming that the S7+ big bore has the same components as the Connoisseur, which I think it does, except for the pulley itself, your machine might have the wrong eccentric shaft fitted! The big bore headstock has many detail differences to the old S7 version, one of which is that the backgear cluster sits further to the left in a big bore machine than it does on an old S7, so the eccentric shaft seems to be longer. Can't say by how much exactly – I measured the shaft from my S7 when I had it dismantled for the poly-vee conversion, but I haven't yet measured the shaft from the Connoisseur – but I think, from comparing my machines, that it's about 1/8", so you might (unlikely, but might) have an eccentric shaft from an S7 in there. On the other hand, given what I've learnt about Myford's assembly quality on their demo machines, I wouldn't be entirely surprised.
