There is quite a bit on google, including one site called? zobobo, it has a vidio by Tubal Cain on the workings of the hot air engine,(I'm on dail up about 12,000 miles away, and could'nt get it properly). Have a look at The site suggested by russell, they do'nt actually show the GAMMA type of motor that yours is, but go back to the single cylinder example, just imagine the piston (r/h one in the diagram ) is in another cylinder. 'Fraid I build 'em but I'm not that great in writing a description of the workings.
The glass part is the displacer cylinder, the displacer is the bit inside that moves, when it is in the foreward position (leaving an open bit visable in the tube), the air gets heated, it expands, increasing the internal pressure, this pushes the power piston down, the displacer moves back, filling the hot space, and opening the cold end where the air cools, the pressure drops, and the atmospheric pressure pushes the piston back up the cylinder ready to start all over again. There are no valves in a Stirling Engine, the air stays in the engine, it's just heated and cooled as the displacer shuttles from one end to the other.
he animations the first one you see is actually the same type as yours, except it opperates at low temperature, usually hot water, but some have been built that will run on the heat of your hand.
These motors can be adictive, I'v got 17 working ones that I'v built, and ideas for a few more I would like to try.
Ian S C
Edited By Ian S C on 26/03/2012 08:28:15
