Posted by Chris Vickers on 14/12/2019 17:32:30:
Could I ask what the difference is between Stevenson's original collet blocks and any other available, and are the ball bearing caps worth having instead of the plain.
Cheers
Chris.
Generally agree with what has been said before Chris but will add a few other things which might be useful. It's a kind of 'Evolution' story in terms of my collet collection…
Before the JS ER32 Blocks were available, the (Hobbyist) Trade only offered 5C collet blocks – so that's what I originally purchased. 5Cs will hold up to 28mm round stock but you can also get square and hex collets. They are for just a 'single' size but that may not be a problem for specific projects (I only have a few sizes). The quick release lever-type 5C holder can be more convenient than ER when working on multiple parts.
At this time I also had a 'Chinese' MT2 collet chuck (with non-ER collets) – but we can skip over that as ancient history…
My Spin Indexer was also 5C but then JS introduced his ER32 adaptor for it – so I started to use (and like) ER32 collets. In terms of work holding size – you can now get ER40 of course (max 26mm?) but I'm invested in ER32 – so the 5C is still handy occasionally.
I also have a 'bearing' nut that gets used when I really need to take a ER32 collet down near it's minimum – and it does make life much easier (especially if you have trouble gripping things too hard) but for anything near the 'max' diameter of the collet – the normal nut is perfectly useable. I've also mentioned before that a few Imperial collets can help in this area – If I have some 6.2mm material to hold – a 1/4" (6.35mm) collet is easier to use than a 7mm one…
All my collets/chucks have come from Arc Euro (and I've no complaints) – so I cannot speak to other suppliers.
Collets & Collet blocks are very useful things to have and the more you use them – the more uses you seem to find for them. Hope this hasn't been too far off-topic…
IanT
Edited By IanT on 15/12/2019 15:13:10
