Steel tube for sand muller
Home › Forums › Materials › Steel tube for sand muller
  • #537227
    richard perrin
      @richardperrin87256
      Hi, Have been watching Mark Preslings U Tube videos of his sand muller build, would like to build one as i'm getting to old and weary to be mixing by hand!
      any idea where i can obtain the steel tube for the roller, 170mm dia by 160 long
      as you can see i only need a short length, needs to have a reasonable wall thickness, i live in Oxfordshire near Chipping Norton.
      Richard
      #30123
      richard perrin
        @richardperrin87256
        Sand Muller
        #537228
          M-machine have a couple of thicknesses in 168OD and will cut to length
          #537234
          Les Jones 1
            @lesjones1
            Possibly a rear roller from a cylinder type lawn mower.
            Les.
            #537239
            Bazyle
              @bazyle
              As Les says rather than slavishly following a design see what is to hand. Eg saucepan with plate welded on, multiple discs eg weight lifting discs that turn out to be concrete not nice iron. I'm no expert but think a muller rather than a mixer is more for oil bonded sand that is caked in use.
              Keep updated on what you make – I hope to need one too one day (due to need to use not due to debility).
              #537248
              richard perrin
                @richardperrin87256
                Hi, Thank you Bazyle.
                I am using oil bonded sand, tried Greensand can't get on with it, my problem nothing to do with sand quality.
                Richard
                #537250
                Speedy Builder5
                  @speedybuilder5
                  Steel lamp posts – sometimes see them at the scrap yard. I found a bit of 8" some years ago for a log stove chimney
                  #537253
                  ega
                    @ega
                    Posted by Speedy Builder5 on 31/03/2021 14:49:28:
                    Or a condemned air compressor tank?
                    #537255
                    Dalboy
                      @dalboy
                      As a temporary stop gap have some turned from some Oak or some other hard wood
                      #537258
                        Just to save too many more from making suggestions of rather thin tube the one in the video looks to be 10mm wall and is a "tyre" around some old lifting weights, the 12mm wall stuff from M-machine that I suggested earlier is more in keeping with whats likely to be wanted.
                        #537320
                        richard perrin
                          @richardperrin87256
                          Thank You all, Think i might have a look around the local scrap yard tomorrow where i buy my scrap Alloy Wheels they are usually quite helpful.
                          Richard
                        Home › Forums › Materials › Topics
