Loctite 542.
Occasionally I have had to have a fitting tighten fully into its correct orientation and it has been a case either making the fitting so it does just that (by skimming the joining face on the fitting), or else turning up a washer of the correct thickness. You have to work the thickness out (or how much to skim off) by using the thread pitch and "angle the fitting needs to turn" formula.
Say you have a 32TPI fitting; if you tighten it fully and it ends up 230 degrees beyond where you want;
You would need a thickness of 1/32" * 230/360 = 0.020" near enough.
I make my special thickness washers out of something fairly hard (usually bronze) and shove in Loctite 542 as well.
