Les,
Could I have ever imagined when I penned my original enquiry for a rubbery coating that it would bring forth such a range of alternative solutions?.
I did say that the wire was pulled through and the capstan provides the pull.
The whole thing is part of a wire winding device and the capstan drive pulls wire of a bulk reel, 100mm dia x125 wide 2kg in weight but varying through the draw off of wire and equally varying inertia characteristics.
From the capstan the wire is taken through a series of pulleys that create a buffer length of wire that copes with the cyclic demands of the winder (Av draw off rate 0.3m /sec but instantaneous wire velocity is varying from 0 to 0.6m/sec at a rate of approx 3 cycles/sec in a pseudo sinusoidal way.
The buffer mechanism is linked by sensors to the capstan drive motor and regulates the capstan speed to match demand. (As long as the wire doesn't slip)
The original configuration did rely on a nipping drive with a Hellerman shrink sleeve on the driven wheel but the wire cut through the sleeve very quickly so I had to move on from that.
I'm not looking for a total redesign of the system, rather a simple, reliable increase in friction characteristic over the wire on tufnol combo.
I'm hoping the improved design using a rubber band, as mentioned earlier will prove sufficient, but if you can identify a easily applied tough rubber coating I would still consider it as an option.
Bob D
