Source of Silver Steel
Home Forums Materials Source of Silver Steel
Viewing 7 posts - 26 through 32 (of 32 total)
  • #309375
    Brian Sweeting 2
      @briansweeting2
      Slightly off topic but having looked at the OP link to GROUNDFLATSTOCK.COM they have useful heat treatment data sheets for all of the products.
      Thor 🇳🇴
        @thor
        Thanks Brian, data sheets downloaded.
        Thor
        #309409
          Posted by John Stevenson on 29/07/2017 18:29:10:
          Learn how to chill out.
          I used to run round. In 44 tonnes artics, no I make do with an estate car
          You think that's a come down?
          I used to have a second generation RX7, now I have a Fiat Stilo…
          Ian S C
            @iansc
            If you heat treat your draw bar, it will need to be tempered carefully or the thread will crumble, and if the tempered area stops abruptly you have a good chance of cracking. If you have to have other than mild steel, 4140 is what I would use, it can be heat treated, but in this case is ok as is, it takes a thread better than silver steel(thats what I'v found)
            Ian S C
            #309519
            Samsaranda
              @samsaranda
              Ian many thanks for the info, perhaps I won't heat treat but anyway your info stored away for future reference.
              duncan webster 1
                @duncanwebster1
                4140 is EN19 near enough
                #309539
                Anonymous
                  Agreed that silver steel can be a pain to thread using a die. It seems to tear only too easily. But it is no problem screwcutting. The thread on the right hand end of this embryo cutter is 25mm diameter 20tpi Whitworth:
                  It was hardened and tempered with no apparent ill effects. Here it is in action on a steel worm wheel:
                Home Forums Materials Topics
