Sine Vice
Sine Vice
Home › Forums › Workshop Tools and Tooling › Sine Vice
  • #294540
    Brian Abbott
      @brianabbott67793
      Hello all.
      I need to buy a sine vice for a part i need to make, has anyone any recommendations of any ?
      I found this one on the net which seems very good value.
      Thanks.
      #18488
      Brian Abbott
        @brianabbott67793
        #294543
        Emgee
          @emgee
          Hi Brian
          The sine vice looks OK but I prefer an angle table used in the same way as the sine table, it does not restrict the size of the part being machined like a vice does. The one I have has Tee slots and tapped holes in various places so a vice can be bolted down if required.
          It was made from castings many years ago to the Dave Lammas design, I beliieve it was written up in the ME magazine. You will of course have to machine the castings so requires a milling machine to make it.
          Emgee
          #294544
          Vic
            @vic
            There's this one as well.
            ronan walsh
              @ronanwalsh98054
              They are only suitable for grinding surely ? Not robust enough for the stresses of milling ?
              #294550
              John Reese
                @johnreese12848
                If you will be using the vise for milling I would suggest an angle vise intended for milling. It will not incorporate the sine feature. You can use a small sine bar to set the angle accurately, either on the mill or on a surface plate.
                #294642
                Brian Abbott
                  @brianabbott67793
                  Thanks chaps for the reply's
                  I wanted the vice to enable to to drill some holes at differant angles, but on reflection i think i will use a sign bar with my small vice clamped against an angle plate.
                  Thanks again.
