Silver solderinga boiler
Home › Forums › Locomotives › Silver solderinga boiler
  • #1893
    Ken Ratcliffe
      @kenratcliffe25229
      #443493
      Ken Ratcliffe
        @kenratcliffe25229
        Hi, I have started on a traction engine using the How to.by George Hughes. I cannot get the silver solder to run on the boiler. I am using a mapp gas torch with a second butane torch, I have the boiler mounted in fire bricks and I have cleaned the surfaces (sandpaper, wire wool and a pickle bath). I am using Medium Silver Solder Strip, with Easy Flo Flux Powder 250g UN3288
        Any help, suggestions or direction to existing threads much welcomed
        #443506
          "Medium" is a term mostly used for jewellery solder not the type used for boiler work so not ideal. you want a 55% solder this also melts at approx 100deg C less than the medium.
          Your heat sources also sound too weak for all but teh very smallest of traction engine boilers you want something with at least 7kw mimumum.
          These weak burners will also take a long time to get any heat into the work by which time your Easyflow solder will be exhausted, better to use Tenacity No5 or HT5.
          Have a read of the guide "best brazing practice" on CuP's site
          Edited By JasonB on 27/12/2019 16:30:34
          Edited By JasonB on 27/12/2019 16:34:25
          #443509
          Ken Ratcliffe
            @kenratcliffe25229
            HI Jason,
            Thanks for the input……as you can guess, this is my first foray into steam engines ! I will get hold of those products and have another go !
            Ken
            #443513
            Dave Halford
              @davehalford22513
              Hi Ken,
              Where did the firebricks come from? The ones from a fireplace soak up all the heat and are useless.
              You need the CUP style hearth bricks or thermalite blocks or even mineral wool from loft insulation ( just not glass fibre)
              #443516
              Former Member
                @formermember19781
                #443521
                Ken Ratcliffe
                  @kenratcliffe25229
                  I had some Vermiculite firebricks……so definitely from a fireplace. I will get some Celcon blocks as well as 55% silver solder and HT5 (already ordered !)
                  Thanks
                  #443874
                  Bill Dawes
                    @billdawes
                    Hi Ken,if you don't mind taking some advice from a beginner in silver soldering terms, I too struggled with my 5" loco boiler (my first and not yet finished) I found things much improved after changing to a bigger burner, a Sievert 2943 I think, about 43kw.
                    I also found you have to be patient, it takes quite a while to heat a boiler up to 600+ degrees for the solder to melt. I use 455 solder in the main, 438 on bits that are likely to be reheated a few times.
                    I usually get my solder and flux from the excellent CUP Alloys.
                    My hearth is an old BBQ stand and using builders aerated blocks, they seem to work well, cuts easily if you want to make any special shapes, I also bought some wool blanket from CUP.
                    I can well understand the frustration, it seems that everybody but you finds it easy.
                    Good luck.
                    Bill D.
                    #443883
                    old Al
                      @oldal
                      My first boiler attempt was a 2" traction engine boiler and i followed a similar path to you. Complete failure. As described above, the flux gave out long before the solder started to run. I also used only one grade of silver solder and had to heat almost all of the boiler material. so as i was heating one part, another part let go on me. Oh it was fun. I did learn a lot.
                      If your finances allow, treat yourself to an Oxy propane outfit. Loads of heat and localised.Even on a 2 1/2" loco boiler, the results are significantly different.
                      Silver soldering is not difficult with the right equipment , a bit of knowledge and help, good luck
                      #447288
                      Ken Ratcliffe
                        @kenratcliffe25229
                        Hi – took a while, gradually doing various things, but in the end, I think it was heat ! Or at least not enough heat ! I got a Seivert burner, backed up with a Mapp gas torch and low and behold the solder ran !
                        Here's another one then……..It looks like in my beginners mode, I may not have got solder everywhere, i.e. my boiler may leak. How best to remedy that. No way I can restart now, bond way too good, so how can I patch any leaks ?
                        Thanks to everyone who helped me get this far, all good fun when it works in the end !
                        #447294
                        Former Member
                          @formermember19781
                          #447295
                          Keith Hale
                            @keithhale68713
                            Hi Ken
                            Take the time, make the effort, understand the process. Learn what you have to do and why.
                            There are no shortcuts. These inevitably lead to poor and expensive joints.
                            There is no better source of information than CuP Alloys. Their livelihood depends on their customers being successful. We have guys who have, between them, over 100 years experience of promoting efficient brazing on a daily basis.
                            Ring 01623 707955.
                            Or see them at ally pally.
                            They are more accessible than a forum
                            Success is at the end of a very short tunnel!
                            Keith
                            #447298
                            old Al
                              @oldal
                              There must be someone in your local club that has oxy propane. Its a pinpoint flame that can be directed straight at the leak area without affecting anywhere else
                              #447307
                              Keith Hale
                                @keithhale68713
                                Hi Ken.
                                The root cause of all silver soldering difficulties lies in one place – behind the torch. Poor joint design.fluxing, heating technique, alloy selection to name but four!
                                Make the joints correctly first time and there is no need for any rectification.
                                Ask yourself – where did I go wrong. A poor joint is the product of a deviation from the basic principles of the process. Appreciate that and you are well on the way to successful brazing.
                                An oxy-propane torch may enable you to recover the situation but it inevitably produces local thermal stresses that can cause other problems. Be aware of that and react accordingly.
                                Instead of trying to put over the situation in a few lines on a forum, why not discuss it with people who know? Old fashioned it may be, but talk-talk is better than chalk-chalk.
                                And the next statement is aimed at all model engineers. Can you spare 10 minutes to get help quickly. Why not use Skype or a video call to show us the problem?
                                Keith
                              Home › Forums › Locomotives › Topics
