silver soldering-not getting burnt
Home Forums General Questions silver soldering-not getting burnt
Viewing 25 posts - 1 through 25 (of 31 total)
  • #260625
    Bill Dawes
      @billdawes
      What do you guys wear when silver soldering, just watched a youtube video of a couple of guys soldering a boiler and wore no gloves or overalls, I wore both on my first attempt at my Emma Voctoria boiler and was getting extremely uncomfortable towards the end of doing the throatplate, both hands and body.
      I had do pull my hand away very quickly in the last bit and messed it up a bit.
      Gloves were builders leather type so have now got some welders gloves, not tried them yet but I fear they might be rather cumbersome.
      Is it me just being a wimp, I have always thought I had quite a high threshold of pain.
      Thinking about it now I think it was the hand holding the solder rod (which of course is getting shorther all the time) rather than the burner hand.
      Any tips ?
      Bill D
      Bill Dawes
        @billdawes
        #260633
        Chris Gunn
          @chrisgunn36534
          Bill, I find gloves a hindrance as well, one thing I do is when the solder stick is getting short, stick it to the next rod and then you can move your hand back a bit. Alternatively hold the short end in pliers or jam it into the end of a piece of dowel.
          Chris Gunn
          #260638
          Russell Eberhardt
            @russelleberhardt48058
            I've found these to be pretty effective. Not as resistant as leather gloves but better insulation.
            Russell.
            #260641
            mechman48
              @mechman48
              Welders gloves are cumbersome for a reason, to protect against heat; ( & UV rays / spatter ) welders keep having to move / rotate manageable items & as they weld the heat generated is obviously imparted to the metal so they need to be thicker to allow some time to manipulate those smaller items. As someone who has done welding on site & workshop, & taught apprentices brazing / silver soldering I can verify that the thicker gloves do give you extra protection & time, but even they get bloody hot in a relatively short space of time, the ordinary leather gloves don't resist heat very well & trying to pull off hot thin leather gloves isn't as funny as it looks, as far as those on YouTube not wearing gloves… thinking … even gas welding / brazing / silver soldering gives off a lot of heat so you will inevitably end up with radiated heat burns at some point, even the silver solder / brazing rods pick up & transmit heat… my tuppence worth fwiw. No doubt there are more qualified welders out there who can describe / give a better explanation…
              George.
              #260642
              MW
                @mw27036
                Well my friend, it all depends on the size of your burner!
                Probably isn't a good idea to hold the object your heating and by that i mean holding an end of a shaft whilst the other is being heated.
                Should always use tongs(not sure where to get decent ones, you can get some with vee grooves for holding round stock as well) and gloves or an appropriate jig. You can get some vermiculite bricks on ebay and put them together with wood screws to make a hearth.
                It's expensive but try to get the 55% silver rods and flux powder, with the gel flux stuff too. It will be much easier to work with on a small burner, i found out the hard way when i went for 40% crying
                Michael W
                #260646
                Bill Dawes
                  @billdawes
                  This is video in question https://www.youtube.com/watch?v=lPTzix5SYAI.
                  Some of you might know these asbestos men.
                  Question how many men does it take to solder a model boiler.
                  Bill D.
                  #260647
                  Bill Dawes
                    @billdawes
                    Sorry my text went a bit awry
                    #260648
                    Bill Dawes
                      @billdawes
                      Michael, I am using the Sievert 2943 43kw burner, I did not have much success with my 2941 7kw on earlier attempts at silver soldering, expert advice on this forum convinced me that the problem was not heating up quickly enough. Certainly made a substantial difference to annealing times for the plates.
                      Soldering with HT5 flux and 438 rods on this bit of the boiler.
                      Boiler placed in my 'forge'. an old BBQ and aerated building blocks.
                      Bill D.
                      #260651
                      Speedy Builder5
                        @speedybuilder5
                        For big stuff, I use the gauntlet gloves that came with my log stove, very thick with cotton wadding inside. Seemed a shame to use them for putting logs onto the fire.
                        #260658
                        Roderick Jenkins
                          @roderickjenkins93242
                          Hi Bill,
                          I'm engaged in a very similar process to you and equipped myself with a pair of these Cheap and cheerful but do the job.
                          When I started work in the '70s, firing thick film circuits we used asbestos gloves surprise for handling the hot stuff. So impressed with these was I that when I saw a pair for sale at a MEX I snapped them up. How times change.
                          Rod
                          #260661
                          Nick_G
                            @nick_g
                            Posted by Michael Walters on 12/10/2016 14:58:38:
                            Michael W
                            Where have the photos of your mini boiler construction gone Michael I cannot find them.?
                            Perhaps the OP would find your expertise of some educational value. smiley
                            Nick
                            #260663
                            John Hinkley
                              @johnhinkley26699
                              Fed up with getting sore pinkies lifting hot cooking dishes out of the oven with standard oven gloves, I bought a couple of separate gloves from my local Wilkinson's store. They seem to be made of a cotton-like weave with knobbly bits of plastic on. Sound awful, but, by golly, they are good. Supposed to be able to withstand up to 450°F. They are very flexible and comfortable to wear but I don't do silver soldering so I'm not sure how the temperature compares. £2.99 a pop.
                              Here's a pic:
                              Silver solderers form a queue to blow the idea out of the water!
                              BC Prof
                                @bcprof
                                I too find gloves a pain in the ……….. so I use artery forceps to hold the solder .
                                The solder is held in place by the, locking. clamping action and they are long enough to keep fingers away from the hot bits .
                                #260683
                                mark costello 1
                                  @markcostello1
                                  Over here We can get Kevlar oven gloves for around $6 a peice, never used They for workshop use, might be worth a try.
                                  Edited By mark costello 1 on 12/10/2016 18:15:58
                                  #260685
                                  MW
                                    @mw27036
                                    Posted by Nick_G on 12/10/2016 16:10:26:
                                    Nick
                                    Well it's nice to know it was being paid attention to. The project is in rehab at the moment so i'll post more when it's done.
                                    I still have the original boiler, its kind of a water pot for the grinder cheeky
                                    Michael W
                                    Edited By Michael Walters on 12/10/2016 18:33:04
                                    #260689
                                    nigel jones 5
                                      @nigeljones5
                                      bare arms and no gloves for soldering with the oxy gun, far too much potential to set myself on fire! I use thin goat skin gloves for TIG, availible ont auction site realy cheap. You will surely get burned holding flux, I hold it in a small pair of mole grips so you can use all but 5mm of the rod. Hope this helps.
                                      #260691
                                      duncan webster 1
                                        @duncanwebster1
                                        For holding short bits of silver solder I just drill a blind hole about 1/2" deep up the end of a bit of 1/4" bar, hole size just bigger than silver solder, then put a slight bend in the silver solder 1/4" from the end and push it into the hole. Never fails, and costs nothing, doesn't risk spoiling forceps. Always wear cotton overalls, I'll never forget the sight of a welder where I used to work when some hot stuff set his shell suit alight. Potentially very nasty as man made fibre melts, sticks to you and burns. He was ever after known as 'Bob the flambee'd welder'
                                        #260698
                                        KWIL
                                          @kwil
                                          Never use the silver solder down to less than say 2", toss that bit aside and start another rod.
                                          Then join up all these short pieces and treat it like a new long rod.
                                          #260743
                                          julian atkins
                                            @julianatkins58923
                                            I agree with KWIL; when for boiler making the silver solder rod gets to less than 6" it gets thrown aside and replaced with another. The 6" throw aways are of course carefully picked up off the burns in the workshop carpet and used for other less intensive jobs.
                                            I never use gloves, and also do all my silver soldering indoors, with the doors open. A curtain can be drawn across my workshop patio type doors to shield from the sunlight so can silver solder big stuff in all conditions.
                                            Cheers,
                                            Julian
                                            #260748
                                            61962
                                              @61962
                                              Posted by duncan webster on 12/10/2016 18:55:03:
                                              I have a refinement on Duncan's solder holder. I use a rod like his fitted to a wood handle which has a square of 16g steel sheet attached to the end as a heat shield. Works a treat.
                                              Eddie
                                              #260751
                                              peter walton 1
                                                @peterwalton1
                                                If you are worried about the heat get a pair of Kevlar gloves not cheap but good for the job
                                                peter
                                                https://www.cromwell.co.uk/shop/personal-protection-and-clothing/cut-protection/product/p/PLY9611313D
                                                Like these
                                                Edited By peter walton on 12/10/2016 23:14:26
                                                #260762
                                                julian atkins
                                                  @julianatkins58923
                                                  I dont know anyone who makes lots of silver soldered copper boilers who wears gloves, and I've been at this lark of making boilers for my own locos for quite a few years plus known the likes of the late Reg Chambers and the late Alec Farmer, and John Ellis, all professional boiler makers.
                                                  Cheers,
                                                  Julian
                                                  #260780
                                                  MW
                                                    @mw27036
                                                    Posted by peter walton on 12/10/2016 23:06:42:
                                                    peter
                                                    Like these
                                                    I should hope £7 isn't too taxing. cheeky You won't get much silver soldering equipment for less than £10 so that isn't too bad for a pair of gloves, you should've seen how much the handstitched leather gloves were the rich used to wear on their trips into town in the motor car a long time ago.
                                                    Michael W
                                                    #260790
                                                    KWIL
                                                      @kwil
                                                      Posted by julian atkins on 13/10/2016 00:20:33:
                                                      Cheers,
                                                      Julian
                                                      Midnight trumpet blowing again
