I did not comment on the Mig question as I only have a stick welder but these are a few bits stuck together with a cheap stick welder and details added by silver soldering.
12" high A frame, base was also welded to form the two legs from 3mm plate and then top and bottoms soldered on
10" long engine frame, smaller parts soldered on and then welded together
Cart crossmembers all soldered about 10" long
If you do decide to weld I would suggest making the width a fraction larger and then milling back to final size which will take care of any movement during welding. Welding needs more time to clean things up well at least with my welding it does and also depends on what you are happy to see.
Edited By JasonB on 24/01/2018 07:45:47
