silver solder paste
silver solder paste
Home › Forums › Beginners questions › silver solder paste
  • #89807
    Eric Cox
      @ericcox50497
      Is it worth using silver solder paste or does it work out too expensive
      #6113
      Eric Cox
        @ericcox50497
        #89808
          Is it still available? I thought it was only made in the Easyflow range which had cadmium in it. Can't see anything listed now on Cup alloys or Reeves the only stuff on google is jewelry silver solder paste.
          But yes its expensive so best kept for small joints and it may have had a shelf life.
          If you want to apply small amounts beat it out with a hammer and cut with tin snips.
          J
          #89813
          Fil
            @fil
            CUP Alloys of Chesterfield still list it
            http://www.cupalloys.co.uk/455-silver-solder-paste-10gm-syringe-i2504.html
            Don't buy all their stock, I want some – I must get on and order it!
            #89814
              Well spotted Fil, I was going by the pictures so didn't see it as they have the foil pic not the syringe.
              J
              #89948
              Maurice Cox 1
                @mauricecox1
                The jewelers' supply firm Cookson Gold list 30gm syringes of silver solder paste in three different melting points. The cost just under thirty pounds per syringe. It is an excellant way of getting the solder just where you want it, and have confidence that the solder has fully penetrayed the joint.
