Sieg SX3 Gib wobbling
Home Forums Manual machine tools Sieg SX3 Gib wobbling
  • #178722
    Herman Leung
      @hermanleung98574
      Greetings! I'm new here and I'm from Hong Kong. (very rare hobby mechanist in here)
      Recently, I purchase a SX3 in China and encountered a problem.
      Before cleaning, I used an indicator to check the alignment and it is OK, perfectly aligned.
      After I stripped the table to clean all the packing grease and lubed it before assembling. After that, I check the alignment again, I found the needle on the dial indicator jumping a lot while i move the table(~0.03mm) and I suppose it means there are wobble in the gibs.
      I have already tightened up the gibs while the table can still move freely, but i just can't figure out whats is going on.
      Herman Leung
        @hermanleung98574
        #178765
          Hello Herman,
          Welcome to the forum.
          I believe the SX3 has taper gibs.
          You could do worse than read through Arc Euro Trade's SX3 preparation guide.
