Posted by JasonB on 06/10/2012 07:44:14:
The Nemet engines were built on an X3 not a SuperX3.
I have the X3 and did not strip it and its still going strong some 5-6 years later but mine did not come from a supplier that offers a rebuild service so could have been built to a different spec as it did cost slightly more.
J
Jason is correct. The Nemet engines were built on the X3 and not the SX3.
Even though Jasons X3 came from a different supplier, all the factory assembled machines are built to the same spec., be it from ARC or Ax. What you choose to believe and pay is up to you. What I can tell you is that we give feedback to the factory from our observations, which are relayed back to the shop floor production team, for them to consider, sware at ARC, and implement, if they so wish. At present, ARC does not offer a prep.service for these machines.
Just a note: If you are comparing the SX3 with a WM18, please be aware that you are comparing a 1000w DC brushless motor on an SX3 with a 1,100w brushed motor on a WM18. As far as ARC is concerned, there is a difference. Having said this, the WM18 is also a good machine. At the end of the day, the decision is yours.
As Terry and others have said, go and have a look at Warcos WM18 and other clones at the exhibitions to help you decide.
Ketan at ARC.
