Sent lathe back
Sent lathe back
Home Forums General Questions Sent lathe back
Viewing 25 posts - 26 through 50 (of 62 total)
  • #446600
    Andy Carlson
      @andycarlson18141
      I thought it was the locking pin for the swivelling headstock but I think that would be parallel, not tapered. Mine is missing so I dont really know what they look like.
      Hollowpoint
        @hollowpoint
        It is indeed a locking/locating pin for the headstock. I think he meant the end is chamfered rather her than tapered.
        #446617
        Dell
          @dell
          Sorry yes I did mean chamfered.
          #446630
          Dell
            @dell
            Michael
            the column is 1 1/4”
            #446631
              Posted by Derek Allum on 14/01/2020 20:34:20:
              Michael
              Thanks for the confirmation
              … I now have to rack my remaining brain cells, in hope of remembering which enlarger it came from.
              [ not that it really matters ]
                If it's from an enlarger it is probably going to flex under heavy cuts as it will be relatively thin wall tube.
                If this happens, it won't be ridiculously expensive to replace it, perhaps with a solid bar.
                Might be worth beefing up the base board as well, I forsee much flexing when milling otherwise.
                The lathe itself is a nice wee machine,some nice articles on accessories by Terry Gorin about four/five years ago in Model Engineer's Workshop.
                peak4
                  @peak4
                  Posted by Neil Wyatt on 15/01/2020 16:56:14:
                  For a substantial solid baseboard, check out your local kitchen worktop fitter, or ebay for a slab of granite kitchen worktop.
                  Slow to drill, but OK with a diamond bit, and cuts fine with a dry-cutting diamond angle grinder disk in a hand circular saw, though you do need to make a hole size adaptor for the blade.
                  That's why you bought a lathe isn't it, for making little bits and bobs as well as models.
                  Depending on the accuracy you need, it should also allow for sliding a height gauge round the base when setting up/marking out.
                  Bill
                  #447180
                  Dell
                    @dell
                    I 5e5d68bd-460a-4749-8ed3-3ead80bbdfd3.jpegWell I don’t seem to have any luck regarding lathes yesterday I got the chance to have a look at the lathe and I noticed that the live terminals were exposed as are the DC terminals and I was going to teach my grandson to use it, if he put his hand on there at the very least he would be sent across the room and at the worst it could kill him see pictures.
                    I have a friend who is an electrician coming to look at it next week ,as you may guess the seller doesn’t want to know so I have put it in the hands of Paypal, will let them sort it out .
                    That is the trouble with eBay nothing is checked as to weather it is safe to sell and in my opinion it is dangerous to have exposed 220volt AC and 220volt DC terminals exposed.
                    Dell
                    #447183
                    jimmy b
                      @jimmyb
                      Simply looks like a missing cover.
                      Jim
                      #447185
                        Frustrating as it is, Derek … that should be just a simple rewire job.
                        Let’s hope the previous owner was a better mechanic than electrician !
                        … Fortunately it does look that way.
                        jimmy b
                          @jimmyb
                          I know I'm a better engineer than electrician…..
                          #447192
                          Dell
                            @dell
                            Going to see what the electrician thinks next week .
                            the shaft bearings are shot as well but that is easy to sort .
                            #447193
                            Andy Carlson
                              @andycarlson18141
                              If it was me then I'd be sorting out the electrics to a point where I was happy with them. This is what I've done with three of my lathes (two from eBay one bought privately). It's delaying day when you can use the machine but once it's done it's done.
                              I'd be wanting an outer casing around those terminals, something like Hammond plastic project boxes from RS or similar. I'd want strain relief grommets on the cables where they enter the outer box so that if the cables are pulled the force is not baing taken by the electrical terminals. Also check the fuses in the plugs – 3A is probably plenty but all of mine arrived with 13A.
                              For bigger machines I'd want an NVR power switch and maybe an emergency stop button but I dont have either on my Unimat.
                              I've no idea where you stand if you want to complain to the seller or eBay. The discussion threads I've seen seem pretty rambling and inconclusive on this point.
                              Regards, Andy
                              #447200
                                Wouldn't worry me at all – the connections just need to be covered, either with a insulated sheet or by putting the whole lot in a box. If that's all that's wrong with a second-hand lathe of that age, you got off lightly!
                                Can you let us know how this pans out with ebay and PayPal? Buying second-hand can be a minefield when it goes wrong, and it will be reassuring if this dispute is fixed to your and the sellers satisfaction.
                                Good luck,
                                Dell
                                  @dell
                                  The chap I purchased the Unimat lathe off decided to have the lathe back and refund my money, So I have bitten the bullet and purchased a Cowells 90ME ( I think I need to have a lie down).
                                  i know I am a fussy sod but I wouldn’t be happy teaching my grandson to use it as I wasn’t happy to use it myself.
                                  i still have the case open with PayPal as I haven’t got refund yet because I have only just sent it, but the fact that he has agreed that I can return it will go in my favour if I have to go back to Paypal .
                                  i am looking for some accessories for it the shaft is 14X1.5 if anyone has a chuck lying around they want to sell please PM me.
                                  Thanks Dell
                                  #447860
                                  Former Member
                                    @formermember19781
                                    #447871
                                      Posted by Derek Allum on 20/01/2020 19:14:33:
                                      Thanks Dell
                                      Hurrah, that's a good outcome. A hard-nosed seller might have held you to the contract, but this chap has done the decent thing.
                                      Is this a new Cowells you've bought, about £3000 with no accessories? Quite a jump from a second-hand mini-lathe! Nice machine, please share how you get on with it.
                                        You would be better off looking for a M14 x 1 threaded chuck, anything else won't fit and you will have something else to send back. See Cowell's site for headstock details including spindle nose.
                                        #447875
                                          Posted by JasonB on 20/01/2020 20:41:51:
                                          Depends on the age of the lathe …
                                          [ I'm not sure what exactly you bought, Derek … but here is the early spindle ]
                                          Former Member
                                            @formermember19781
                                            #447881
                                              Posted by 34046 on 20/01/2020 21:04:58:
                                              The Cowells from memory is 14 mm by 1 mm ?, but I stand to be corrected.
                                              Bill,
                                              Is now = Yes
                                              Was always = No
                                              See previous post
                                              Raphael Golez
                                                @raphaelgolez
                                                Hi Derek, the 14 x 1.5 spindle is the old version. Did you purchased the Cowells lathe in ebay that was sold lately with an indexed back gear? It is a very good example of the earlier version. The problem with it is finding a M14 x 1.5 chucks. It also have a fewer speed range as evident in the motor pulleys.
                                                I have the newer M14 x 1 spindle. It also have a full adjustable micrometers on all handle and a reversing switch with a start stop buttons. The advantage of the newer spindle thread is you can fit the Unimat 3 chucks which are very easy to get. I was nearly tempted to sell mine but decided to hold on to it as it hold its value well especially the M14 x 1 spindle. I was also selling my full Unimat 3 lathe with Milling machine and with motor which is an excellent example. I was so insulted when somebody offered me 30 GBP for it. I know his plans as he buys it and sells it a a chopped parts for extortionate price. I know how much this lathes worth and with a top condition it commands a good price. I pulled it out as it looks perfect on my collection display. Enjoy your new lathe!
                                                Raphael
                                                Edited By RAPHAEL VAL GOLEZ 1 on 20/01/2020 21:24:14
                                                #447933
                                                Hollowpoint
                                                  @hollowpoint
                                                  I know the guy selling the one on ebay and I have seen it in the flesh so to speak. It is definitely an m14x1.5 spindle. The lathe is in super condition, so if that is the one you have bought I doubt you will be disappointed.
                                                  And ive just seen it is now sold so take care of it because I know the owner was very reluctant to sell it!
                                                  #447935
                                                  peak4
                                                    @peak4
                                                    Posted by Michael Gilligan on 20/01/2020 21:15:31:
                                                    Bill,
                                                    Is now = Yes
                                                    Was always = No
                                                    See previous post
                                                    Agreed, when I bought my Simat in the early '80s it came with a 14×1.5mm spindle.
                                                    The 3 jaw and backplate came with it, but as I recall, I ordered the threaded body 4 jaw separately as an early Cowells type.
                                                    Bill
                                                    #447947
                                                      I thought the ME90 that was said to have been bought is the newer version not the 90 that the spindle drawing is for.
