I'm embarassed to be making this post but here goes. I have to drill some holes about 0.8 mm diameter through 6 mm thick brass. To accomplish this I thought a sensitive drilling attachment would be a good idea. I purchased a micro drill adaptor from Arceurotrade which looks exactly the same as in the catalogue – but I cant figure out how to use it
The only thing I can think of is that I need to make a hollow sleeve, hold this in the drill chuck, insert the shaft of the micro drill in the sleeve and bring the whole ArcEuro bit of gear down by pressure on the knurled wheel.But if this is the case what drives the shaft of the attachment?
All advice gratefully received except how to do the job without an ArcEuro sensitive attachment
Regards, Chas
