securing tungsten contact points
Home › Forums › Clocks and Scientific Instruments › securing tungsten contact points
  • #3713
    derek hall 1
      @derekhall1
      #222940
      derek hall 1
        @derekhall1
        Hello all,
        I have an electric clock (GPO type 36) that impulses the pendulum by a "Hipp Toggle" which has its original contact points burnt out and destroyed. I have purchased a couple of tungsten points from our good friend Kirk at Hemmingway Tools (no connection other than a regular customer), thinking that I could use these to replace the original burnt out ones.
        My line of thinking is that loads of old petrol cars used to use "points" and distributors etc, these points being tungsten I assume.
        So to my question how do I secure these tungsten points to the thin brass parts of the Hipp Toggle? can I soft solder tungsten to brass?, is there such a thing as conductive glue for example?
        I am looking forward to your replies!
        Best wishes
        Derek
        #222942
          I have silver soldered Tungsten contacts for some of my engines.
          J
          #222943
          KWIL
            @kwil
            This was the advice given to Jason by Cup Alloys
            "Proceed as you thought with your silver solder and flux.
            Keep joint gaps small say 2-3 thou.
            Use propane to heat so you get good all-round heating of the joint.
            Allow to cool slowly.
            Keith"
            and it obviously workedsmiley
            #222947
            Roger Provins 2
              @rogerprovins2
              Silver soldering will be the best but electro conductive glue is available.
              See eBay 262244630569 for instance.
