If sufficiently well-made and lapped-in, the conventional taper plug-cock is as good as any, and plenty of these appear among model locomotive designs. Designs for generic model engine fittings seem not to exist apart from a few samples in various text-books.
Cut the female taper using a D-bit type taper reamer made from silver-steel, on the same angular setting as turning the plugs. The better the reamer’s finish the better the mating surface inside the valve.
The modern versions as used in domestic plumbing replaces the plug with a ball, held between two O-rings; one on the inlet, the other on the outlet sides. It is rotated by a tang working in a shallow slot, like a screwdriver and screw.
You can see how these are arranged by dissecting a scrap domestic-plumbing valve. Note that the diameter of the ball has to be significantly larger than the pipe bore for full flow. The slim-line domestic valves have quite small passages that must restrict the flow considerably. So a full-flow ball-valve may be a bit disproportionate but could be disguised as a globe-valve by machining the outside to a matching spherical form.
For the smaller model size, you could use a stainless-steel or phosphor-bronze ball, cross-drilled in the lathe with the ball gripped in a suitable collet resembling a pipe union.
Taper plug-cock bodies usually have a matching taper on the body. Make the body from two pieces of rod, silver-soldered together then machined.
