Schrader Tap
Schrader Tap
Home Forums General Questions Schrader Tap
  • #388721
    Kevin F
      @kevinf
      Hello , I need to tap an internal thread for a valve cap 8v1 .307 X 32 tpi , now the question is do I need the schrader tap which is expensive or I’ve found a 5/16 x32 tpi tap at a very reasonable price ,would the unff tap be ok
      Kevin F
        @kevinf
        #388729
        Chris Evans 6
          @chrisevans6
          I often make the round knurled retaining nuts for motorcycle inner tubes because new tubes tend to come with hexagon nuts and do not look right. I use 5/16" x 32 tap without problems.
          #388749
          Kevin F
            @kevinf
            Thanks Chris yes
            #388811
            michael howarth 1
              @michaelhowarth1
              Whilst on the subject of Scrader valves, what is the internal thread that takes the valve insert?
              Mick
              #388848
              Howard Lewis
                @howardlewis46836
                I thought that Schrader valve threads are 0.75mm pitch, although if U S A manufacture are much more likely to be to an Imperial standard.
                There was a similar discussion on here, some time ago.
                If you can find it, that may be a help.
                #388853
                  32 tpi for that diameter
                  I think the insert is 0.210" x 36 on a car size v8 valve
                  Edited By JasonB on 02/01/2019 11:45:48
                  #388888
                    Perhaps this summary would be useful: **LINK**
                    https://ipfs.io/ipfs/QmXoypizjW3WknFiJnKLwHCnL72vedxjQkDDP1mXWo6uco/wiki/Schrader_valve.html
                    … unless, of course, someone has a more definitive source that contradicts it.
                    Edited By Michael Gilligan on 02/01/2019 14:19:01
                    #389504
                    michael howarth 1
                      @michaelhowarth1
                      Posted by mick H on 02/01/2019 08:47:33:
                      Whilst on the subject of Schrader valves, what is the internal thread that takes the valve insert?
                      Mick
                      Michael's link gives it at 5.30 x .7 something , but fiddling around this morning, !BA is as near as dammit and seems to work well.
                      Mick
                      #389571
                      Howard Lewis
                        @howardlewis46836
                        The Model Engineers Handbook gives 1 BA as having a top diameter of 5.3mm, and a pitch of 0.9mm
