Satellite TV Cable Induced signal. One cable, 2 channels
Home › Forums › Electronics in the Workshop › Satellite TV Cable Induced signal. One cable, 2 channels
  • #488653
    Speedy Builder5
      @speedybuilder5
      I have been having signal problems, Dish to Humax . We live in a "Fringe" area for the signal and after 15 years, the cables – Dish to receiver have started to 'perish'. Anyway, I replaced one of the cables some time ago and it was time to replace the other as the signal received on the oldest cable was 'weak'. So I removed the cable from the LNB and left it dangling whilst I threaded a new cable. However, before connecting the new cable, I saw that the same strength signal came from the Humax channel connected to the old cable (But no connection to the LNB). The cables run in cable ducting about 8 metres long.
      Any ideas as to how that works ?
      #32118
      Speedy Builder5
        @speedybuilder5
        #488675
          A satellite cable has to be terminated with a 50ohm resistive load at both ends before the signal is contained inside the screen. In this case both cables are open ended allowing the LNB to use one as a transmit antenna while the Humax sees the other as a receive antenna. Neither accidental antenna has to be efficient because they're close together in the conduit. The signal should disappear if a 50 ohm resistor is put across the open end of either cable.
          Martin Kyte
            @martinkyte99762
            Well 75 ohms actually.
            regards Martin
