The ER20 collets arrived from RDG and to my dismay the 2mm hole does not look to be in the centre of the collet (where the split lines cross) this is what I could see with the chinese one I had before. – Maybe it is my imagination but I don't think so. They do seem to be machined/ground though and the chinese ones aren't but you can also see some manufacturing errors.
Anyway 1st test I check the run-out setup the same as the video I posted earlier and I get 0.045 – so only slightly better than the Chinese one.
I'll go and measure some-more and re-check the collet holder in case that's a long way out…
What's the consesus on oil on the collet and tightening torque – I'm giving a reasonable nip with a 300mm spanner I may try a few 'tightnesses' and see if things seem to get better or worse.
Only 1 more thing – I'm using a drill bit and measuring on the shank, I'm assuming that should be a reasonable method. – also it means this is likely the best possible result as the run-out is likely to get worse further away from the collet (i.e. at a drill bit tip where it actually matters…)
Edited By Men Ifr on 14/11/2017 17:33:52
