Step 1: Set, and lock, the rotary table on zero.
Step 2: Lightly bolt down the rotary table, indicate on one of the four slots while moving the appropriate table axis. Tap the rotary table to reduce indicator movement, when the indicator doesn't move tighten the bolts.
Step 3: Use one of these:
in conjunction with the parallel hole in the centre of the rotary table to set the DRO on 0,0. For those who don't recognise the unit it's a Haimer Centro.
Having completed all steps the rotary table will have its cardinal points aligned with the X and Y movements of the mill, and the DRO indicates the centre of the rotary table. Doesn't take long, probably a few minutes.
Edited By Andrew Johnston on 27/06/2018 22:28:16
