As has been said may times; if all else fails, read the Instructions; assuming that you have, or can access, them.
The 60-0-60 scale, surely is a Vernier scale to improve the resolution of the angular division.
(Not that the Vertex manual refers to the Vernier scale. It just assumes that you know what it is and how to read a vernier).
The Vernier scale allows you to move the Handwheel in small increments,as outlined above.
The gear ratio for the Vertex HV6 Rotary table is 90:1, so 30 turns of the handle will give one third of a turn of the table, and so on, or use the degree scale on the edge of the table, so that you rotate the table the required number of degrees, (say 72 degrees, if you wanted five divisions, 60 degrees for 6 divisions, and so on). As long as you bring the Handwheel back to the same point every time, it will give an accurate result
If you are going to use any of the three Division Plates available for the HV6, DON'T trust the chart at the back of the manual. I did, and made three scrap gears, before spending time to make an EXCEL spreadsheet, which corrected the EIGHT errors and omissions. Using the spreadsheet figures, allowed me to cut a good 13T gear.
(See my thread on this Forum on the HV6 errors. Stub Mandrel has posted the spreadsheet on his website).
Anyone having a Rotary Table, or Dividing Head with a ratio other than 90:1 has only to change the gear ratio, and the number of holes in the Division Plates, in the formulae, to have a spreadsheet for their equipment. (I HOPE!)
Edited By Howard Lewis on 20/03/2016 16:06:21
