Rotary table
Rotary table
Home Forums Manual machine tools Rotary table
  • This topic has 52 replies, 16 voices, and was last updated 1 May 2018 at 23:07 by Michael Gilligan.
Viewing 25 posts - 1 through 25 (of 53 total)
  • #351633
    Richard Clark 1
      @richardclark1
      Hi is it possible to get 133 divisions from a 90:1 rotary table?
      I have the index plates that can be fitted but not sure on how you would even go about working it out the maths?
      Index plates are
      A Plate/
      26, 28, 30, 32, 34, 37, 38, 39, 41, 43, 44, 46, 47, 49,
      51, 53, 57, 59
      B Plate/
      61, 63, 67, 69, 71, 73, 77, 79, 81, 83, 87, 89, 91, 93,
      97, 99
      If anyone has any ideas I would be grateful
      Many Thanks
      Richard..
      Richard Clark 1
        @richardclark1
        #351636
          Sorry, Richard
          The first solution is 90 holes on a 133 hole plate.
          You will probably need to make a temporary plate.
          This should help: http://www.cgtk.co.uk/metalwork/reference/divider
          Edited By Michael Gilligan on 25/04/2018 21:29:27
          #351638
          Richard Clark 1
            @richardclark1
            Hi sorry I dont know what you mean 90 holes on a 133 hole plate?
            regards
            Richard..
            #351641
              Richard,
              133 is a prime number, and doesn't feature on your set of plates sad
              You need to make a temporary plate with 133 holes, and then index by 90 holes for each of your divisions.
              Life's tough sometimes … but at least doing it this way evens-out the errors in that temporary plate.
              P.S. .. You might find this recent thread of some interest:
              http://www.model-engineer.co.uk/forums/postings.asp?th=135034
              Edited By Michael Gilligan on 25/04/2018 21:41:14
              #351643
              HOWARDT
                @howardt
                Using b plate put index pin in 99 hole circle. Rotate 67 holes in 99 plate. This gives 99/67 * 90 = 132.985, an error of 0.015/360=5.4deg.
                Anyone closer?
                #351650
                HOWARDT
                  @howardt
                  Error is wrong only 0.0404deg over 133 holes. 67 holes in 99 hole plate 133 times
                  #351651
                    Your expedient solution is very clever, Howard yes
                    It probably wouldn't have crossed my mind, because I only ever look for an integer solution.
                    That said: I'm afraid I still don't understand either version of your error calculation.
                    I'm probably tired … but grateful if you could elaborate.
                    Keith Long
                      @keithlong89920
                      Posted by Michael Gilligan on 25/04/2018 21:34:22:
                      Richard,
                      Er – no it's not – it factors as 7 x 19
                      So it may be possible to devise a way of indexing for 133
                      #351718
                        blushblushblush
                        richardandtracy
                          @richardandtracy
                          You are looking for 0.676691729 turns of the handle each time (90/133)
                          With the 99 plate and 67 holes each time, you will get an error of 7.5947 x 10^-5 turns error each hole, or a total error of 0.0404 degrees. I am assuming the 99 plate is attached to the handle & rotates once per 4 degrees.
                          Richard.
                          Edited By richardandtracy on 26/04/2018 13:52:36
                          #351720
                          Bazyle
                            @bazyle
                            Posted by HOWARDT on 25/04/2018 22:53:43:
                            Do half the holes in one direction then half in the other direction. That halves the accumulated error.
                            Although a 90 wormwheel is different from 40 (!) 133 doesn't appear in the standard B&S or Elliott tables for simple indexing so it is a problem one.
                            The maths is wormwheel x plate holes then divide by the target division in this case 133. If it is a round figure you have a winner of the number of holes to index.
                            #351721
                              Posted by Bazyle on 26/04/2018 13:50:20:
                              That's where I started … and the 'first' answer is given by
                              (90×133) divided by 133 = 90
                              Keith may be onto something, but I can't get my head around it just now.
                              Edited By Michael Gilligan on 26/04/2018 13:59:34
                              #351722
                              Bazyle
                                @bazyle
                                Posted by Keith Long on 26/04/2018 12:38:21:
                                Richard,
                                The way you use this is to look for a plate that is a multiple of either 7 or 19. The obvious one is 38.
                                You then do the calculation from my previous post and find it gives a non integer. Bother. but all is not lost. What you do is not cut the first tooth, nor the second etc until you get to the 7th. This is spot on, then another 7 etc. This gets you 19 off teeth cut spot on. You can then use the 99 hole plate to fill in re-zeroing at each of the existing teeth so the accumulated error is less.
                                Actually you can use the 28 (after the 7s above) and cut the teeth at 19 intervals. Then re-zero on a 19 and do another set of 7s. Then back to 19s. A bit difficult to re-zero on  teeth but if you are cutting a 133 index plate it would be possible to set on a hole more easily, then with your accurate 133 index plate cut your gear.
                                Edited By Bazyle on 26/04/2018 14:16:45
                                Edited By Bazyle on 26/04/2018 14:33:49
                                #351724
                                richardandtracy
                                  @richardandtracy
                                  Used excel & the brute ignorance & force method.
                                  Richard
                                  #351727
                                    Posted by richardandtracy on 26/04/2018 14:23:57:
                                    Thanks for that, and for your earlier post, Richard.
                                    Personally, I would be happier using the temporary 133 plate, but it's good to see the alternative.
                                    #351752
                                    John Haine
                                      @johnhaine32865
                                      There's a hole in my bucket…
                                      Seems to me that almost any temporary plate will be less accurate than a good rational integer approximation.
                                      #351753
                                        Depends how accurately you make your 133 hole plate. If you can punch the numbers into a DRO and make the ring of holes as large a dia as possible you will get a very accurate result. No less accurate than a CNC produced plate. It will give you an exact number not an approximation.
                                        #351756
                                          Posted by John Haine on 26/04/2018 18:14:56:
                                          A temporary plate, whilst 'maybe OK' for direct indexing, should be quite adequate when the errors are 'distributed' by the 90:1 reduction ratio.
                                          Jason's wise comments stand, of course.
                                          Edited By Michael Gilligan on 26/04/2018 19:00:09
                                          #351757
                                          Trevor Crossman 1
                                            @trevorcrossman1
                                            Richard​ , my suggestion to solving your division plate difficulty is to use this….https://www.blocklayer.com/circle-dividereng.aspx. Select 'circle divider' then put in however many holes you want and then use your printer to print out in an appropriate size, glue to a steel disc and accurately centre and drill. I use double side tape because it does not distort the paper by shrinkage. If at all possible, print the largest size that you can fit onto a spindle under your mill or drill, so that you can 'target' the divisions at a large radius but drill the holes on a co-axially mounted disc at a smaller radius. This will minimise any dimensional variations in your drilling. A temporary indexing device can be made up with a magnetic stand and a scriber, and a magnifier to augment the view.
                                            Trevor
                                            #351761
                                              Posted by Trevor Crossman 1 on 26/04/2018 19:08:38:
                                              That's a nice alternative to the one I suggested yesterday, Trevor yes
                                              I will add it to my ever-increasing bookmarks.
                                                Richard​ , my suggestion to … use your printer to print out in an appropriate size, …
                                                Trevor
                                                That's a really good idea but do check your printer has actually drawn an accurate circle on the paper before drilling! My printer produces a slight oval unless the margins are switched off
                                                Richard Clark 1
                                                  @richardclark1
                                                  Hi, to all
                                                  Well thanks for all the great input this is why I posted on here as always there seems more than one way to skin a cat!.
                                                  The printout idea I have saved for future print outs but as others have said my printer seems to also print oval on a good day on a bad day its stretched?.
                                                  I knew I was in way to deep on my own as maths was always a non starter with me especially when your all talking about things like prime numbers and rational interger whatevers I could not see the woods for the trees..
                                                  I like the idea of using the 99 hole plate, that at the moment would to me seem to be the most accurate
                                                  And thanks for the formula Bazyle (The maths is wormwheel x plate holes then divide by the target division in this case 133. If it is a round figure you have a winner of the number of holes to index). that is going to be printed out and stuck near my rotary table
                                                  Really great stuff on here as I was stuck with the maths
                                                  Richard wink
                                                  #351779
                                                  Anonymous
                                                    I think there's more of hole in your maths. smile
                                                    For an approximation the error may be small per division, but it is cumulative, so you can guarantee that after the correct number of moves you will not end up back at the start point. Depending upon the approximation one will either be short, or overshoot.
                                                    With a division plate, with the correct number of holes, you can guarantee that after the correct number of moves you will end up exactly back at the start point, and in the same hole on the division plate, within the accuracy of the worm and worm gear. If the holes are not evenly spaced then you will get errors, but they are cyclic, and not cumulative, so they will cancel out overall. And, as MG says, any errors in the position of the holes are reduced by the worm gear ratio.
                                                    So while it is not definitive I'd back a home made division plate over an approximation any day.
                                                    #351782
                                                      Thank you, Andrew
