Posted by Emgee on 27/12/2019 12:21:26:
Lot of talk here about Chinese VFD's and the likely use of low cost components that may prove to have a short life.
Is this all assumption because of a much lower cost or has anyone dismantled and checked component suitability in the imported units ?
Certainly not a lot of failures reported on this forum in the last few years, plenty of reports ref poor programming information but most have got things sorted.
Emgee
It's a tricky one. First, any modern up-to-date maker of electronic components is likely to be using exactly the same machinery and materials as everyone else. It may be difficult for patriotic Brits and Americans to accept, but Chinese manufacturing can and does perform in the international first division. As does India, Brazil, Mexico, and any other country where it's convenient for investors to set up a factory.
But not everyone is up-to-date. Factories using obsolescent equipment to knock out second class goods (as the British Car Industry did in the 1970s), and new old stock, seconds, and forgeries are all possible. While it's not difficult for an assembler to source decent components and pay for competent designs, its also easy for less respectable types to make a quick buck by knocking out rubbish!
Second, technical improvements aren't always used to improve reliability. Older electronic components (and machines) tend to be sturdily built – oversized, over-engineered, and over-priced. Replaced 1 for 1, the best newer technology always outperforms older. Unfortunately, stuff isn't replaced one for one in the products we buy. Instead, reliability is often exchanged for miniaturisation, running at a higher-temperature, and reduced manufacturing cost. Planned obsolescence is more common than not.
Generally, it can be assumed that sellers of reliable cost-effective gear will survive, whilst over-priced sellers of reliable gear go to the wall as does anyone making gear that is cheap and nasty. It's actually hard to make a living out of tat – too much hassle for low profits!
Twenty years ago it was fairly safe to assume Chinese electronics would be inferior. Absolutely not so today. Once a modern factory has paid off the initial set-up costs, it's remarkable how cheaply it's possible to churn out good products. This is what we are seeing today – the benefits of mass-production coupled with inexpensive labour selling into a global market. But it's NOT safe to assume that everything made in China is wonderful – it's not!
The current generation of budget VFDs bought from a reliable vendor are likely to be competent performers. Not the best available, but good enough to run a home machine without costing a fortune. Imperfections, yes – Robert's comments about missing EMC are all too valid!
I've not dismantled a cheap VFD. Forty years ago I took Japanese electronics apart and found glaring quality issues, today I'd be amazed to find anything wrong. Fifteen years ago, Chinese electronics was often dubious: now the bulk of the world's consumer electronics are Chinese and of good quality. If you want to believe China makes nothing but rubbish, pound shops are your oyster. Otherwise, buy something expensive and prepare for a shock…
What's interesting is who will become the next centre of manufacturing. At the moment China is doing well, but it may be a bubble. Could be we see manufacturing shift somewhere else fairly quickly as the world moves on. Africa and South America are both candidates whilst transport is cheap, but high-fuel costs would shift the advantage back to local manufacture of long-lasting goods again.
Meanwhile, I'd be prepared to try an inexpensive VFD should I ever need one!
