regulator material
regulator material
Home › Forums › Locomotives › regulator material
  • #380919
    Philip Burley
      @philipburley44197
      I am starting to make a screw down regulator for a small loco , What materials would be best for the valve ? Bronze for the base and stainless for the taper part was what I was thinking of What do others use ?
      regards Phil
      #1772
      Philip Burley
        @philipburley44197
        #380992
        David Wasson
          @davidwasson11489
          Yes, bronze for the seat and stainless for the valve works quite well. – David
          #381005
          Philip Burley
            @philipburley44197
            Thanks David , I will carry on with that set up then # I take it that the valve seat is bored straight through and not tapered ?
            regards Phil
            #381036
            David Wasson
              @davidwasson11489
              Hi Phil,
              Yes, the bore for the seat is straight though, no taper. For the thread on the valve, I used a 1/2"-13. When you turn the regulator handle, it is full open at about 1/4 turn. I made it a right hand thread, as I wanted the regulator to open when you turn the handle anti-clockwise. Farther than this does not really change the steam flow.super simplex regulator - jpg.jpg This is the drawing for the regulator in my Super Simplex. – David
              You will find more photos of my regulator at my website. Scroll down about a quarter of the page.
              Edited By David Wasson on 17/11/2018 13:56:35
              #381044
              Philip Burley
                @philipburley44197
                yes , that's the drawing I am working from , scaled down , Its for a big boiler Tich . Thanks for that link , very useful . ( and interesting )
                #381046
                David Wasson
                  @davidwasson11489
                  Philip, you are so welcome! I'm glad you have found the link useful. – David
                Home › Forums › Locomotives › Topics
