As Muzzer says, a gauge is useless to determine how much gas is left until there isn't any left. the only way is to weigh the bottle against the Tare weight stamped on the bottle.
The 19kg is the charged weight and is usually painted on, the Tare weight is stamped somewhere.
I work in refrigeration / air conditioning, and people are often confused that a system is showing a good standing pressure, which they equate to it having a good gas charge, until the compressor starts, and suddenly there's no pressure due to the system having lost most of its bulk gas charge. This is the same if it's a small system holding a couple of kg's of gas or an industrial system holding up to a tonne.
