Product Descriptions (Up to scratch?)
Home Forums Beginners questions Product Descriptions (Up to scratch?)
Viewing 7 posts - 26 through 32 (of 32 total)
  • #447743
    ega
      @ega
      To their credit, some chuck makers mark the jaws to indicate how far they may safely be used when projecting from the body (by "safely" I mean without undue risk of tooth breakage).
      Nicholas Farr
        @nicholasfarr14254
        Hi, I agree with ega's words of wisdom, which is how I uderstood the marks and I have a 100mm 3 jaw with such marks, which will allow 100mm diameter max solid bar to be held with the outside jaws or a 100mm inside diameter max, piece of tube with the inside jaws. My 80mm on my mini lathe however, will only allow 70mm with the above stated limits, although a near to chuck diameter could be done with only the lightest holding pressure, as the No. 3 jaw will be on its last tooth. Hope this helps.
        Regards Nick.
        P.S. the other limiting factor to consider, is the amount the jaws sticking out of the chuck, don't catch any part of the saddle in such occasions that the saddle passes under the chuck during the work progress.
        Edited By Nicholas Farr on 20/01/2020 15:48:51
        #447802
          Posted by Nicholas Farr on 20/01/2020 15:40:14:
          […] My 80mm on my mini lathe however, will only allow 70mm with the above stated limits, although a near to chuck diameter could be done with only the lightest holding pressure, as the No. 3 jaw will be on its last tooth. Hope this helps.
          Regards Nick.
          … and it's perhaps worth noting that the 6" PBA chuck that I linked earlier only claims a maximum capacity of 5"
            Bison give quite a good idea of what the chucks will hold, see the second page of this PDF
            Still does not show them being used like this though where you could hold work upto the max swing of your lathe.
            #447811
            Nicholas Farr
              @nicholasfarr14254
              Hi, that's just cheating Jason, point contact and all that wink 2 but I have done similar myselfangel 2
              Regards Nick.
              #447833
                Posted by JasonB on 20/01/2020 16:11:15:
                … which, I think, nicely demonstrates the point I was making 19/01/2020 20:04:37:
                Howard Lewis
                  @howardlewis46836
                  The C3 mini lathe manual quotes a 180 mm maximum swing over the bed. The maximum DIAMETER over the Cross Slide is likely to be 100 mm, from memory.
                  With regard to the maximum size that can be held by a chuck will depend on whether bar or hollow.
                  100mm bar over the Cross Slide, but a ring upto 180 mm external diameter could be held by chuck jaws gripping the internal diameter, as long as it does not try to pass above the Cross Slide.
                  Personally, I am not a fan of Machine Mart. The local branch lost my confidence years ago. If I were buying a new lathe, I would rather deal with one of the Model Engineering suppliers.
                  Having had no experience of Axminster or or Amadeal, cannot comment. But ranked by my experience of other suppliers, my preference would be Arc Euro, Warco and then Chester. But these are purely my preferences, others may have had different experiences.
                  Edited By Howard Lewis on 20/01/2020 22:21:16
