Hi , Thanks for replys .
David , at the moment i have not got a parting tool so can't try that.
I am sure the material is brass , i have also tried another piece of brand new bar stock 10mm diameter and the effect is the same ! The swarf is small chips. I have machined brass on bigger lathes in the past and know what you mean by 'it gets everywhere'
I have tried all speeds on the high setting from around 1400 to 2800 the vibration is the same , i am only using small cuts of less than 0.5mm (even tried 0.1mm) and feeding by hand. With the smaller cut the vibration is less.
I cannot see it is anything other than the cutting tools as there is no play in the lathe that i can see and the spindle runs very sweet when unloaded , just can't see whats wrong with the tooling im using though , as mentioned i've tried silver steel , the machine mart tools and also now a brand new sumitomo indexable tool. I will try and cut a bit of steel later and report back.
Thanks again for taking your time to help.
Chris.
