Pressure angle of gears in Boxford lathe apron
Home Forums Help and Assistance! (Offered or Wanted) Pressure angle of gears in Boxford lathe apron
  • #33280
    Alan Charleston
      @alancharleston78882
      Alan Charleston
        Hi,
        Can anyone tell me what the pressure angle of the gears in a Boxford AUD lathe apron is? I suspect it is 14.5degrees rather than 20 degrees but I want to be sure before I splash out on some cutters.
        Alan
        #374606
        not done it yet
          @notdoneityet
          You should be able to see the difference in tooth shape at the root. Comparison pics are to be found on the net or in gear cutting tomes. 20 degree pressure angle teeth are wider at the root. I expect (guessing) it will be 14.5 degrees – at least for earlier models.
          #374619
          JohnF
            @johnf59703
            Why not just contact Boxford I’m sure they will advise, I have always found them very helpful
