Something I forgot to ask is whether the jaws have been ground flat on the faces, or axially with a wheel. If the surface is curved, they will have to be checked while sitting on a cylindrical surface. The ideal diameter of cylinder would be about half the width of the jaws, with a shim to hold it on the jaw centreline.
If that 0.1mm slope is just made parallel, you will definitely end up with bellmouthing when the chuck is used, there has to be clearance in the slots for the jaws to move and all jaws have a degree of flexibility.
The last time I ground internal jaws, which are the same way round as yours, the only way to pretension them was to drill holes in them for the tensioner pins. A solid carbide drill was required to get through the case hardening.
Edited By old mart on 22/10/2019 12:43:55
