Possible machine hoist?
Home Forums Workshop Tools and Tooling Possible machine hoist?
  • #460730
    colin hawes
      @colinhawes85982
      I store my heavy chucks on a shelf behind the lathe with a short ramp so that I can roll them into place at the right level to fit them . I have done the same with a heavy dividing head by the horizontal miill .I'm no' so young as I used to be! Colin
      Clive Foster
        @clivefoster55965
        Been reflecting on my earlier suggestion of something mounted on a work cart.
        Scaffold pole pivot at one back corner carrying a two section bent jib, wheelchair hoist style is current favourite. Short strap or chain between the jib and object to be lifted so no winch needed. Either use a ratchet strap so its adjustable or have a couple or three ones of different lengths.
        Actual lift range is inherently limited but making the angle between the jib sections adjustable with a choice of two or three holes for a pin should give enough height flexibility to cope with from floor up to higher than the machine. Albeit in one or two bites with an intermediate table midway to set things on for re-adjustment.
        Looks as if it can be made to fold neatly behind the cart. If working over the cart should be stable enough not to need axuillary support but a brace of fold out legs would be desirable so you can work out of the corner. Maybe screw a paving slab or two under the cart for extra stability. Probably not needful with mine as the drawers are full of spanners et al and the sheves always have heavy "crap" on them.
        #460752
        John Reese
          @johnreese12848
          I have a hoist similar to David's. Mine was intended to attach to the hitch receiver on my pickup. I plan to make a short pipe pedestal that mounts to the floor and just drop the upper part of the hoist into the pedestal. It will be placed near the corner of my 16" lathe headstock and will be used primarily for handling chucks (8" dia).
          #460848
          Bazyle
            @bazyle
            Posted by larry phelan 1 on 29/03/2020 12:06:06:
            Take a look at my Elevating Barrow in my Album, works a treat ! Sad to say, it was not my idea, I just copied it.
            Looks good Larry. More photos please, and some dimensions of material used for uprights.
