Posted by NJH on 11/12/2013 17:59:55:
I 'm just wondering why you are seeking to change to poly V ?
If it is to obtain smoother running then have you investigated link belts? My S7 was rough and noisy in the high speed range so I replaced the primary belt with a link type. Super smooth and quiet at all speeds now. The secondary drive belt is still a traditional 'V' type at present but that too will be changed for the link type when the time comes.
The belt is shown here
Cheers
Norman
A great picture.
I have had one of these belts on my Myford since 2006. I only put it on the outer like you have done as I was not sure of the life or consistency of these belts. When the spindle belt starts to look sad or slips, it will be cutting it off and be replacing it with the sectional belt. I got a piece for the job, but have not got to replacing it yet.
I just could not get over how much it reduced vibration and the surface finish improvement.
The spindle belt was replaced with a Gates belt that has the notches to allow it to bend around the pulleys easier. It has lasted way longer than expected. That belt was replaced back in 1996 or so when I rebeded the front bearing and replaced the rear bearings.
I have not experienced the spindle belt slipping, and do not see the need for a poly Vee belt. But I am also not against anyone making such changes. Each to their own.
