Hi All
Apart from the regulatory and legal liability issues what practices should we adopt to perform polishing in the lathe safely?
To make a start.
Polishing in the lathe
When polishing with abrasive strip I use the following procedure. (this material often has a very strong cloth or Mylar back)
Cut a small piece of cloth as short as possible, but no so short that using it will expose the hands to the fast rotating chuck.
when applying the strip to the work the last 25mm of each end the strip only shall only be grasped between the thumb and forefinger of each hand.
It shall never ever be wrapped around a finger or the hand. (There will be no exceptions to this rule)
Using this method if the abrasive catches it will be pulled away from the opposed finger and thumb, instead if dragging the limb in with terrible consequences.
Filing in the lathe
I must admit I don't like doing it particularly near the chuck. I do not regard it as a safe practice.
The text books say the file must have a handle, absolutely true, or you risk the file tang being driven into your palm or wrist.
But what happens if the file does inadvertently catch the chuck or the work? with a file you have a firm grip with your hands wrapped around the tool. in an instant the tool is projected towards you.
Yes I do it sometimes but I don't have to like doing it particularly near the chuck.
