Phosphor Bronze grade for boiler bushes
Home Forums General Questions Phosphor Bronze grade for boiler bushes
  • #464450
    Matt Stevens 1
      @mattstevens1
      Hi All,
      I am building the 6" vertical AJ Reeves boiler which calls for Phosphor bronze use on the bushes…. trouble is there are lots of grades out there. What type of PB should i be using?
      I have heard there are drawn and cast grades – likely the latter is easier to machine on a lathe where i don't have coolant running. Another point is that i am based in Canada so a grade i can get in North America would be great…
      Thanks
      Matt Stevens 1
        @mattstevens1
        #464451
        Former Member
          @formermember19781
          #464452
          Matt Stevens 1
            @mattstevens1
            Posted by Bill Chugg on 13/04/2020 19:16:51:
            PB102 is what I use.
            Bill
            Hi Bill – Isnt that the drawn stuff? Does it machine ok given i am not running coolant on my 9" lathe?
            I have heard Calphos 90 mentioned alot as well….
            #464453
            Matt Stevens 1
              @mattstevens1
              I see C544 mentioned as a grade…any comments?
              #464454
              Former Member
                @formermember19781
                #464456
                Matt Stevens 1
                  @mattstevens1
                  Thanks Bill….. i see that McMaster-Carr carry 510 and 544 grades. I believe 544 does have some lead in it, buts its more accessible and cheaper. If this is a suitable grade for boiler bushes then it might be a good bet.
                  #464458
                  Former Member
                    @formermember19781
                    #466180
                    Matt Stevens 1
                      @mattstevens1
                      Interesting how Bill's posts have been removed???
                      Anyway, from doing abit of research, it seems that PB102 is a common grade in the UK which is equivalent to C510 in North America. C544 is more common over here yet it doesnt seem that there is a comparable British Standard equivalent. See attached link for info…. **LINK** .
                      I still wonder if both C544 and C510 are ok for boiler use…..i would like to buy C544 which is far more accessible.
                      Thoughts?
                      #466229
                      Thor 🇳🇴
                        @thor
                        Hi Matt,
                        Doesn't C544 contain zinc and lead (in addition to tin)? If so it may not be as suitable as C510.
                        Thor
                        #466294
                        Matt Stevens 1
                          @mattstevens1
                          Yes i believe there is 4% lead in C544. Not sure about zinc…..Could you explain why you think this is a problem for boiler bushes?
                          I believe C544 is much easier to machine also than PB102/C510
                          #466330
                          duncan webster 1
                            @duncanwebster1
                            The spec for C544 is here **LINK** claims to be 'good' for brazing, so should be OK for silver solder as that is slightly lower temp.
                            It appears to be very similar to Colphos 90, **LINK** which machines a lot more easily than drawn PB102, which can be a right pig to drill and tap, it closes up on the drill.
                            Edited By duncan webster on 22/04/2020 15:42:56
                            #466437
                            Thor 🇳🇴
                              @thor
                              The subject was discussed earlier, see here.
                              Thor
