Right, second bite…
So what we’ve established so far is that chatter is always present, but with care in the design of the machine, tooling and by using appropriate speeds etc, we can tune it out of harms way and so produce good work.
This is my take on what happens and is what I believe causes parting-off problems with the commonly available HSS blades when used in the front toolpost:
1/ The cut commences and is initially fine.
My View Is That:-
Depite the tool being quite wide and so removing more material than in normal turning, the basic Machine/Tool/Speed setup is adequate for the job.
2/ Once a certain depth is reached, sensations can be felt through the lathe and the sound of the cut can change. At this point I would say a lot of people instinctively withdraw the tool, clean the groove and carry on.
My View Is That:-
This is the point that the system is beginning to become unstable.
3/ A short while after the cut is recommenced, the cram-up happens – but why?
My View Is That:-
The parting-off blade is now working in a confined space with very, very little clearance.
As various sized chips are generatedby the cutting action, most of the larger ones are ejected by other swarf as it is being produced. However, small, gritty size pieces can remain and some of these will become lodged between the tool and the workpiece and might even ‘pick-up’ or ‘gaul’ the job.
From there, it can be seen that this unstable system is working in a situation where a log-jam can now occur as other swarf is produced.
When the log-jam does happen, the system experiences large forces and from these forces deflections can be seen about the tool and it’s mounting, as well as the visible signs of the work moving too.
So to work around the problem:-
Some folks will widen the groove, before carrying on with the first cut as it gives more room for the swarf to clear.
Some will part-off from the rear, which allows gravity to help keep the groove clear of swarf.
Others will use a specially designed ‘tipped’ tool which curls the chip to make it narrower and also has plenty of clearance at the sides.
Etc.
Martin.
Edited By blowlamp on 21/01/2011 12:30:41
Edited By blowlamp on 21/01/2011 12:31:35
