Oversize ER collets
Oversize ER collets
Home › Forums › Beginners questions › Oversize ER collets
Viewing 15 posts - 1 through 15 (of 15 total)
  • #407893
    Robin Graham
      @robingraham42208
      I need to grip a 28 x 5mm trapezoidal leadscrew so I can turn some threads off to make a shaft, as concentric to the screw as I can, and thought that a collet chuck would be a better option than trying to do it in the 3-jaw. It seems that the standard for ER40 goes up to 26mm, but oversize collets are available. Cutwel and others list precision collets up to 30mm, but these are not compressible. Their compressible collets stop at 26mm. RDG list oversize compressible – I have bought a 28mm one and it looks OK.
      I expect that the RDG collet will meet my needs, but I'm interested that Cututwel et al , who I think supply to a more demanding industrial market, don't offer the larger sizes as compressible. I'm guessing it's because they can't guarantee compliance, but I'd like to understand the why of it.
      Robin
      #9653
      Robin Graham
        @robingraham42208
        #407894
        Paul Lousick
          @paullousick59116
          Why hold the leadscrew in a 4-jaw chuck ?
          Paul.
          #407910
          Paul Lousick
            @paullousick59116
            Correction,
            Why not hold the leadscrew in a 4-jaw chuck ?
            Paul.
            #407929
              Posted by Robin Graham on 06/05/2019 00:03:16:
              Robin
              Could be a complicated answer!
              Suppliers like Cutwel, RDG and others will all have a business plan, likely one that allows them to sell efficiently and profitably. Quite often it pays to concentrate on a particular sector: the needs, budgets and techniques used by industrial users are not those of the typical hobbyist. I don't think strong technical conclusions can be drawn from what vendors choose to sell.
              Industrial users tend to be focussed on speed; they pay big money for fast accurate resetting, balance good enough to spin cutters at 15000rpm, and effective clamping. At the same time, they are likely to take a professional approach to buying 'fit for purpose' rather than rushing out and buying the most expensive item in the Catalogue. Much more planning than an amateur needs to do.
              ER collets are a jolly good thing for both amateur and professional users in that although designed for tool holding, a single collet can also grip work over reasonable clamping distances, usually 1mm. But this is a convenience rather than a universal answer to all work holding problems.
              For a job like holding a lead-screw, I guess Robin is after a collet because they have good grip. An industrial user turning many lead-screws might solve the problem by buying a collet of the right size (not ER – it would be some other system), or by making a soft-collet, or by specifying a purpose built clamp. But for a one off, I think most workshops would go for a 4-jaw chuck as Paul suggests. A 4-jaw will grip as effectively as a collet; the only disadvantage is the time taken centring them, especially if you've not done it before! For a job like this, I would only use a collet if I happened to have one of the right size already, otherwise I'd get the 4-jaw out.
              Differences between home workshop and industrial techniques are worth looking at I think. In Mal Webber's Howitzer thread Niloch posted a link to a silent film showing how 8" shells were made in Canada circa 1917. It's useful viewing for the variety of production techniques used a century ago and comparing them with how a hobbyist might approach the same jobs. In the film work holding isn't done with conventional chucks or collets; rather – in the interest of speed and accuracy – arbours or special to purpose chuck/clamps, some pneumatic are used. Mostly the work is done with lathes, but not general purpose machines of 'our' type. Instead they are customised to do one job efficiently. There's a nice sequence showing parting off in a 'lathe' pulling front and rear cutters together under power; not a standard cross-slide, and pretty useless unless you have a lot of 8" parting to do!
              My point is there are a series of borders and overlaps between hobby machining, jobbing workshop practice, production, and mass production. The best tool depends on who you are and what you're doing; not on 'quality', or 'industrial best practice'. There's a lot to be said for hobbyists buying from hobby suppliers and preferring hobby techniques.
                Get yourself a set of softjaws, they will hold better than a 4-jaw and as the contact area will be much larger you won't risk damaging the crests of the screw which could happen with a 4-jaw as you push and pull the part into position. Also saves the fun of having to run your dti on a screw thread while clocking in the 4-jaw.
                Cutwel's do have a 30mm compressable ER40 in their standard range, not just upto 26mm. Glocester Tools on e-bay have a lot of oversize ER collets.
                Edited By JasonB on 06/05/2019 10:28:22
                #407939
                Nick Hulme
                  @nickhulme30114
                  I bought 29 and 30 some time ago and recently picked up 30, 31 and 32, all of them are marked with the standard 1mm compression range and work fine that way.
                  #407954
                  maurice bennie
                    @mauricebennie99556
                    I have 3 small collets all different. no 1 17mm long outer shaft dia. 10mm hole dia.6.25 mm . No 2 ,19mm long . OD 10mm. hole dia. 8mm. No3.shaft 20mm long . dia. 10mm . hole 5.0mm.
                    NO 4 .This has pull shaft 12 cm long including knurled knob ,internal screwed thread on other end. With this is a
                    collet 3.5 cm long ,screw thread on one end ,on other end a collet with 3.2 engraved on end. this fits onto the above
                    shaft. I have no idea what any of these fit . If there is any one who would like them please ask.
                    MAURICE BENNIE
                    #407974
                      Message sent, Maurice
                      Howard Lewis
                        @howardlewis46836
                        If the Leadscrew can pass through the Headstock, why not turn a close fitting bush in the 3 Jaw, Mark the position of No 1 jaw, before removing, split and you have your own bespoke collet!
                        The bore will be concentric, and being an almost completer circumference, it should grip well.
                        Replace the bush in the 3 jaw with the mark aligned with No 1 jaw, insert Leadscrew, clamp, and machine away!
                        #408029
                        Robin Graham
                          @robingraham42208
                          Thanks for replies. Clearly I was mistaken about the range of ER40 collets – everywhere I looked said 3-26mm so I thought that anything bigger was 'oversize' and accuracy might be compromised in some way. Not so it seems. As I said I have little doubt that the RDG collet will be OK for  what I want to do, I'm not chasing microns, so it was an an acadaemic question I suppose. I was just interested in the limits of the design given the external sizes of the collets in the series. 32mm for ER40 seems pushing it for example – there must come a point where the steel gets so thin that that there is a risk of permanent deformation on compression.
                          I had thought about alternative ways of holding the screw but they all seemed to have problems of one sort or another. Bruising the threads, faff of moving indicator over threads in the 4-jaw as JasonB said, etc. Truth to tell I've had a hankering after a lathe collet chuck for a while but have been working round it – this project tipped the want/need balance: I should grasp the nettle then (with a stiff upper lip) bite the bullet and make one. It's going OK at the moment and will be more versatile than making a custom collet,
                          I've no idea how I would get soft jaws for my 3-jaw. It came with the (Far Eastern) lathe. There are no identifying markings on it. Are the scrolls made to a standard so any jaws for a 6" chuck would fit?
                          Robin.
                          Edited By Robin Graham on 06/05/2019 23:57:08
                          #408040
                            Try Rotagrip, I got softjaws for my no name chuck that came with the lathe from them. They have the measurements.
                            #408059
                            Danny M2Z
                              @dannym2z
                              Posted by Howard Lewis on 06/05/2019 18:02:30:
                              You beat me to it Howard. An aluminium bush bored and split in the 3 jaw would be an inexpensive but accurate way to hold the lead screw.
                              #408873
                              Bernard Wright
                                @bernardwright25932
                                If you still need to go the ER Collet route, Barry @ Gloster Tools (mainly on @Bay) does all the individual oversize collets, at the most reasonable prices I've come across, including free P&P.
                                I have NO association with Gloster other than a very satisfied customer of quite a few years.
                                #412586
                                Zane Crowther
                                  @zanecrowther67531
                                  Hi,
                                  It might be worth contacting this precision engineering company to ask for advice and get a price on an oversized collet? : **LINK**
                                  Zane
