non-circular boring.. Literally – it is boring!
Home › Forums › CNC machines, Home builds, Conversions, ELS, automation, software, etc tools › non-circular boring.. Literally – it is boring!
Viewing 25 posts - 1 through 25 (of 28 total)
  • #461186
    sam sokolik
      @samsokolik60334
      I decided to see if I could create a polygon shaped hole with a little math and a cnc..
      And now in aluminum!
      Edited By sam sokolik on 31/03/2020 04:16:05
      #15266
      sam sokolik
        @samsokolik60334
        #461189
        Thor 🇳🇴
          @thor
          Impressive Sam, now you should be able to make your own socket head cap screws.
          Thor
          #461232
          Martin Connelly
            @martinconnelly55370
            Looks useful. I expect the maths is similar to what is used for single point turning of polygons on CNC lathes with the added complication of a rotating tool.
            Martin C
            #461282
            Brian H
              @brianh50089
              That's excellent Sam, thanks for sharing. I'm just beginning to find out about CNC and it's fascinating what can be achieved.
              #461308
              sam sokolik
                @samsokolik60334
                I expanded on the work Andy did…
                He also did some grinding mock ups..
                #461314
                sam sokolik
                  @samsokolik60334
                  I also am working on the functionality of slaving the x axis to the radius of the polygon… SO you can do things like create a profile for the polygon to follow. So this is a radius into a taper..
                  #461327
                  blowlamp
                    @blowlamp
                    That's interesting stuff you're doing, Sam. yes
                    Could you post some gcode here please, so I can try it with my PlanetCNC control, which is designed to be LinuxCNC compatible?
                    I'll get Alan at cncyourmyford to have a look too as I'm sure he'll be interested.
                    Martin.
                    #461345
                    sam sokolik
                      @samsokolik60334
                      This is a simple hal component that takes the spindle posltion from the encoder and calculates where the x/y axis need to be to keep the tool tip perpendicular to the polygon. (well – to the inscribed circle.) This is done in the real-time layer of linuxcnc. So 1000 times a second it reads the spindle postion and calculates the polygon shape. I use currently the digital/analog i/o functionality in gcode to communicate with the component. I think it could be converted to remap to make it more user friendly. I don't have the gcode here at the moment but I think this is the latest hal component.
                      sam sokolik
                        @samsokolik60334
                        A hex bolt head isn't exactly a standard.. but..
                        #461426
                          Nice !!
                          sam sokolik
                            @samsokolik60334
                            Hmm…
                            #462215
                            sam sokolik
                              @samsokolik60334
                              Broach this! (the vertical lines are the encoder resolution…)
                              #462222
                                Comment rev.1
                                Very Very Nice !!
                                sam sokolik
                                  @samsokolik60334
                                  Ok – I need to get a higher resolution encoder.. Then The surface finish will be better and I will be able to go slightly faster…. (I might have to bake in backlash comp too…. (x axis has a bit of backlash))
                                  #464401
                                  sam sokolik
                                    @samsokolik60334
                                    Phase 2 – Better spindle encoder..
                                    #466228
                                    sam sokolik
                                      @samsokolik60334
                                      Almost done!
                                      #466629
                                      sam sokolik
                                        @samsokolik60334
                                        #467305
                                        sam sokolik
                                          @samsokolik60334
                                          Encoder seems to work better…
                                          #467310
                                            Comment rev.2
                                            Even nicerer still
                                            … I’m clean out of superlatives now angel
                                            sam sokolik
                                              @samsokolik60334
                                              I think I get a D for effort…
                                              #468953
                                              sam sokolik
                                                @samsokolik60334
                                                I do actually talk at about 6:30m
                                                #470666
                                                Thomas Dye
                                                  @thomasdye26707
                                                  I see that continuous stream of chips and wonder how difficult it would be to add chip breaking in the g code?
                                                  Would definitely stop them building up around the tool.
                                                  I suppose it could be done by alternating the path or by over-boring the hole slightly first.
                                                  #470948
                                                  sam sokolik
                                                    @samsokolik60334
                                                    Posted by Thomas Dye on 10/05/2020 16:19:55:
                                                    Other than the spindle synced motion – the gcode is normal. You could do a pause every so far..
                                                    sam
                                                    #471981
                                                    sam sokolik
                                                      @samsokolik60334
                                                      Actual spinning encoder. (thought I put this in another video..)
