I have had a look at the VM250V on the Warco site and I cannot see anything that looks like a screw cutting gear box. In this case you will have to set up the change wheels for each thread you are attempting to cut. That, unless I have missed something.
On the basis that I am correct you may find the changewheel combinations listed on my website of help.
The lists assumes a lead screw having a 2mm pitch and changewheels in increments of 5 teeth
26 TPI equates to a metric pitch of 0.9769mm
My list shows 7 combinations at 0.9768mm but 6 do use a 21 tooth gear.
However, if you accept a very slightly greater error at 0.9778mm there are 21 combinations, many do not use the 21 tooth gear, 3 of which only use two drivers and two driven. These are obviously the ones to use if you have the required gears.
Do you realise George that when lathes are quoted as being able to cut an imperial thread on a metric lathe (or visa versa) that there will be errors in the result, that unless a 127 tooth gear is provided and few do to my knowledge
If the Lathe has other that a 2mm leadscrew, or gears in increments of other than 5, the web page explains how with a simple calculation the required result can be obtained.
Some may wonder why I list so many combinations. This is to cover the situation where a lathe owner does not have a set of changewheels
The web page can be found here– http://www.homews.co.uk/page31.html
Incidentally, the pages also cover for metric threads on an imperial lathe.
Harold
