Need to Anneal ?
Need to Anneal ?
Home › Forums › Beginners questions › Need to Anneal ?
  • #61401
    Steve Lowe
      @stevelowe10419
      I have some new bright mild steel sheet (3mm) in order to build some engine frames for my new project – Gresley N2 Tank.
      Should I anneal these sheets before starting the cutting/filing?
      Many thanks
      Steve
      #5335
      Steve Lowe
        @stevelowe10419
        #61403
        macmarch
          @macmarch
          If you are not required to cut into the thickness of the sheet then you shouldn’t have a problem.  Hacksawing out the slots for the axles will result in the sheet ‘bending’ into a slight curve. This is corrected by the usual method of resting the ends on blocks and applying ‘suasion’ by means of a hammer.  However if the sheet has been sheared to size you may  have a twist.  I leave to others to advise how to get it out.
          ray
          #61404
          Nicholas Farr
            @nicholasfarr14254
            Hi Steve, unless you are able raise the temperature uniformally, and keeping it supported over the whole area of the sheet from cold, you will get warping and distortion. You would probaly be better of using it as is.
            Regards Nick.
            #61405
            Steve Lowe
              @stevelowe10419
              Thanks for the prompt response.
              Yes, it was the tendancy to warp following cutting out of axle slots that I had been warned about. But your reference to ‘suasion’ makes perfect sense to me, especially as I have no means of consistent heating.
              Thanks
              Steve
