Need a Frame 56 size motor pulley
Home Forums Workshop Tools and Tooling Need a Frame 56 size motor pulley
  • #366267
    Ian Austin
      @ianaustin
      Posted by Robin on 08/08/2018 11:20:34:
      Have you actually spun up a Taperlock pulley? Andrew Tinsley said they are neither accurate nor repeatable which is not encouraging.
      I saw that, but I think this is a reference to the concentricity run-out on the taper – possibly an issue in large diameter lower-quality taper-locks, but unlikely to be a problem in the wee little ones we're talking about. There is widespread industrial use now of taperlocks – if they were no good (i.e. maintenance = cost money) they would have disappeared. Also, note in uniformly-loaded low-service factor situations they don't need a key (see Fenner Drives link below), i.e. unless your torque overwhelms the shrink-fit-like grip that the taper exerts on the hub, or you have high dynamic loadings. Mine are for a machine that is still in bits.
      Read this Fenner Drives technical guide on how to use them:
      https://www.fptgroup.com/dss/docs/689_06_Fenner_Shaft_Fixings.pdf
      Edited for better info
      Edited By Ian Austin on 08/08/2018 12:10:31
      Robin
        @robin
        That Fenner thing was interesting, I din't know you could get Taperlock hubs, wonder if I could convert one of them to a grinding wheel holder? I might even be able to balance the blooming thing…
        #366288
          Can you not use a separate taperlock bush and pulley, if you look at this one it puts the V groove on the screw side unlike that one in your opening post and under £10 the pair
          #366304
          Robin
            @robin
            That's the self same advertisement that caught me out…
            Product images are for illustrative purposes only
            Brand may vary unless specified in Name/Description
