Mystery Lathe
Mystery Lathe
Home Forums Manual machine tools Mystery Lathe
  • #95531
    sparky mike
      @sparkymike
      Any idea what make this lathe is?Mike
      sparky mike
        @sparkymike
        Any idea of the maker of this lathe?
        #95532
        sparky mike
          @sparkymike
          A friend has this lathe for sale. Has anyone any idea what make it is?
          I have not got the hang of posting pictures yet. Guess I need a smaller size !!
          MIke.
          #95536
          John Stevenson 1
            @johnstevenson1
            Mike,
            Edit it to be 350 wide.
            #95539
            Sub Mandrel
              @submandrel
              Or right click and choose 'view image' – displays it full size and correct proportion.
              Blimey! For a relatively small lathe that is built like teh proerbial brick outhouse!
              Have you looked on lathes.co.uk?
              _Paul_
                @_paul_
                Looks really hefty!
                Does it come with any backgears? the pic makes the fitted ones look quite fine sourcing additional ones could be a problem.
                #95550
                Harold Hall 1
                  @haroldhall1
                  Have you noticed, the hand wheels look decidedly oval, I think the aspect ratio has been changed and the lathe is nothing like what the picture implies. Much longer that is!
                  Harold
                  #95553
                  Brian in OZ
                    @brianinoz24148
                    re the pic of the lathe, if you follow Stubbs advice above the picture comes out Ok on your monitor, agree a 'chunky' little lathe, the gap bed would be handy..cleaned up would be a good addition to any workshop..
                    #95556
                    Ady1
                      @ady1
                      No leadscrew handwheel? How strange
                      No leadscrew clutch either, a myford habit
                      We really need to see the headstock to be sure, behind the metal guard
                      A nice long sculpted tailstock, like a Boley or a Pultra
                      Edited By Ady1 on 02/08/2012 01:32:11
                      #95561
                      sparky mike
                        @sparkymike
                        I have some more pictures I will resize them and see what happens. The headstock is partly built up with thick steel 1/2" or 3/8" plates. Not a repair, but looks original. It must weigh in very heavy due to the strong outhouse construction !! The bed looks to be very over engineered as well. At the moment the saddle is stuck, probably as the lathe has not been used for some time. I was going to purchase it ,but the Myford came along the same week. This one has enough swing to skim car brake drums so would be handy for a classic car enthusiast. I could not detaect any play in the head bearings but did not check with a dial gauge, just a block of wood for a lever and by feel. I did email Tony at Lathes UK re. make, but as yet no reply, so guess he is on holiday ? If anyone is interested message me.
                        #95562
                        sparky mike
                          @sparkymike
                          Three smaller pictures of the above lathe.
                          sparky mike
                            @sparkymike
                            I have now had a chance to take four pictures of the headstock in detail. They can be found with link below. The headstock is built up out of very heavy steel plate which is rare but not unique.
                            Mike.
