Having learned a lesson about correct sequence of operation of the tumbler gears, I have my new tufnol gear waiting to be fitted….
Question is how do you remove the tumbler lever to replace the gear?
I see an inclined grub screw with locking nut behind the pivot lever. Is this holding it in place?
Any other advice you have on the subject also welcome.
Cheers, Colin
