Myford Super 7 Gearbox – Help Required
Home Forums Manual machine tools Myford Super 7 Gearbox – Help Required
  • #77285
    Steve Talbot 1
      @stevetalbot1
      I have just removed the top cover from a newly acquired Myford Super 7 to enable a thorough inspection and clean out of the gearbox. Unfortunately having removed the cover I moved the upper lever ( which moves the quadrant plate) a little too far, and, you have guessed it, the locating pin A2521 & D5/1922 launched into space never to be seen again. These parts provide the A,B & C locating detent points for the upper lever.
      It seems that parts are unlikely to be available from RDG/Myford so what I need to know is what is locating pin A2521 like. Is it in fact a ball bearing or a specially shaped pin and is the spring
      Any help would be appreciated.
      Steve T
      Steve Talbot 1
        @stevetalbot1
        #77327
        NJH
          @njh
          Hi Steve
          Examining my Quick Change gearbox manual (with a magnifying glass !!) the drawing references are 199 – 13529 Spring and 198 – A2521 Locating pin. It certainly appears to be cylindrical rather than spherical and may? have a rounded end. I do own a Myford but I really don’t want to take off the top of the gearbox to check I’m afraid!
          I see from a recent thread though that a couple of ex Myford guys are offering service of Myford lathes – see Myford Lathe Service thread on this site. Why not give a call – they may be prepared to help.
          Good luck!
          Norman
