Hi again,
Sorry, I have only just been able to try some things out.
It appears to have fixed itself……Today, I tried the idea of running de-clutched, all ok.
Tried again at the highest lathe speed, and again, the same symptoms with the added note of the continuous clicking of the motor.
Checked all the bearings, no, heat at all.
As a thought, I tried running it in reverse, again at full speed, ran for 2 mins, no problems???
Based on this, I tired again in forward, and three times in a row, each of about 2 mins, no problems at all!
So i can only assume that something was catching / rubbing, and by reversing, it freed it…I am wondering if the belt was getting caught in the back gear cluster, as the pulley and the gear are close to each other, and a frayed bit of belt would cause a lot of resistance?
Thanks again,
Nicholas
