Just for general interest :
Bearing materials need to be chosen on basis of running speed , bearing load , effectiveness of lubrication and life needed between renewals .
For a lathe with a moderate usage factor and moderate loads and speeds an unhardened shaft working in whitemetal bearings is certainly quite adequate . As the load , speed and usage go up better bearings come to be needed .
Myford realised this very early on and as DC points out the the C7 series had hardened shafts and bronze bearings almost from the start . The later S7 series also had hardened shafts and bronze bearings at the more highly loaded nose end as did some of the Myford high speed grinders .
Anyone with a bit of spare time can work out the actual and allowable bearing loads and Z numbers for each of the Myford bearing configurations and estimate which is the best for long term endurance .
Michael Williams .
