Myford ML10
Myford ML10
Home Forums Workshop Tools and Tooling Myford ML10
  • #784205
    notyet
      @notyet
      I hope I am putting thnis i the right place but I find myself in need of some help with a Myford Lathe it is a model ML10.
      I would like to know if anyone knows the threads used on this machine, using careful deduction I have determined the tool post thread is 7/16″ BSF. As it has 18 threads per inch it is BSF and not UNF, the UNF pitch would be 20 threads per inch, at least I think it is. What concerns me is the threads on the side of the carriage that locks the sliding strips in place, does anyone know what they are and indeed any other threads on the machine. I have ordered a 7/16″ BSF tap but I would like to order the rest of them as I will need to clean some of the threaded holes.
      Thanks in advance for your time everyone.
      bernard towers
        @bernardtowers37738
        I think you might be looking at 2BA if the 7 series is anything to go by.
        #784272
        notyet
          @notyet
          Ah, of course, it never occurred to me.Thank you very much.
          #784284
          Diogenes
            @diogenes
            If you are keeping the machine the ML10 manual contains a parts list which provides details of the fasteners etc., as well as other set-up and operation information.
            #784333
            Andrew Crow
              @andrewcrow91475
              Due to the age of design / build of the ML10 I would assume that all threads would be either BSW, BSF or BA.
              Andy
              #784912
              Howard Lewis
                @howardlewis46836
                +1 for Andy’s post.
                BSF and BSW for most threads, and BA for gib strip adjusters.
                #785279
                notyet
                  @notyet
                  Thanks everyone, I have a set of BA taps so got that covered my next question is what is the thread on the spindle nose? and where can I get a copy of this manual as mentioned above?
                  Thanks in avance for your valuable replies.
                  #785292
                  David George 1
                    @davidgeorge1
                    #785308
                    duncan webster 1
                      @duncanwebster1
                      Let Google be your friend, 1.125″ * 12tpi
                      #785357
                      Howard Lewis
                        @howardlewis46836
                        If the ML10 is like the Myford 7 Series, the register is likely to be 1.250″
                        Chuck backplates, already machined for a Myford are available, if you need them.
                        #788919
                        martian
                          @martian
                          ML10 parts list, has a lot of thread sizes. Link below.
                          http://vintagemachinery.org/pubs/detail.aspx?id=9529
