Thank you so much for the reply`s guys !
I think from the measurements Robbo provided that it is the the same size as as ML7,
I have uploaded some photographs to photobucket so you can see the item in question
Robbo, I may take you up on the offer of the ml7 slide to try
I only bought this machine to get the myford gearbox off it for my super7, but now I have had a play around with it, I have decided to keep the gearbox on it and use the machine.
The geared head is a fantastic job ! It would be a great project to copy and adapt it to suit the Myford !
And the spindle bore will pass 3/4" and has a #3 taper, I like the tailstock too, it has a huge amount of travel in the ram.
If I can confirm that the ML7 or super cross slide will fit, I would buy a long type
Is the ML7 cross slide feed screw 3/8" ?
LINK BELOW to pictures
http://s65.photobucket.com/user/rab_mcc/library/hobson%20lathe
Edited By GT390 on 12/12/2014 21:44:28
Edited By GT390 on 12/12/2014 21:45:00
