So I have a Axminster C1 micro lathe from 2010. It had infrequent use from 2010 until 2013/14, and hasn't been used much for the past couple of years. It's still useful, so we keep it. It's obviously pretty cheap and not very well made, but it did the job fine for what it was.
I came to make something this evening – a coffee tamper for my espresso machine – and it seems to have broken. Which is pretty annoying as I had only just started, and it's probably the only time I had used it to make something for myself!
It "jammed" as I was cutting too aggressively. The fault light came up. I reset it, went to start again, but it didn't turn. The power light came up as usual, but it's not turning at all. The belt is intact and seated fine. My only other observation is that the motor does not make a light "buzzing" sound when turned on, as it did before. It seems pretty lifeless…
Any ideas what could be the fault here? Is it simply the motor that is "dead" and needs replacing?
It lives at my parents place these days, due to space, so unfortunately I won't be able to look at it for another couple of weeks at least, or over xmas.
Your thoughts are most welcome!
